Program starting after button pushed
Close
I dont know if i understand you correctly, but I guess you will have to save the status of your programm in a variable and then just check it, if programm is running.. if so.. make what you want while waiting 5sec
int programmStatus = 0;
void setup () {
	Serial.begin (9600);
 	pinMode (A0 , INPUT);
 	pinMode (13 , OUTPUT);
void loop () {
	int odczyt = analogRead(A0);
	if(programmStatus == 0 && odczyt > 200) {
		programmStatus = 1;
		digitalWrite (13,HIGH);
		delay(5000);
		programmStatus = 0;
		digitalWrite(13, LOW);
Do you want the loop() function to only ever run once 5 seconds after the button press or can the button be pressed again ? It looks like the latter.
Save the value of millis() when the button becomes pressed, then every time through loop() check if the required period has elapsed by reading the current value of millis(). If not then keep going round loop(), otherwise execute the required code.
What does the second program do when you run it ?
Formatted properly you may see a problem with the if/else blocks of code
    if (odczyt > 200)
      digitalWrite (13, HIGH);
      digitalWrite(13, LOW) ;
    Serial.println (odczyt) ;  //code from here on will always be executed whatever the value of odczyt
    delay (10);
    delay (3000);
    digitalWrite(6, LOW); //power supply off
Much of the code above will always be executed whatever the value of odczyt. Is that what you intended ?
See if this does what you want:
int odczyt;
 Serial.begin (9600) ;
while(!Serial) ;
pinMode (A0 , INPUT) ;
pinMode (13 , OUTPUT) ;
 pinMode(8, OUTPUT); //first buzzer
 pinMode(7, INPUT_PULLUP); //button as input
 pinMode (6, OUTPUT); // POWER SUPPLY
 digitalWrite(8, LOW); //first buzzer off
   while(digitalRead(7) == HIGH);  //if button pushed
   delay (3000); //
   digitalWrite(8, HIGH); //first buzzer on
   delay(1000); //Czekamy 1 sekund
   digitalWrite(6, HIGH);  //power supply on
   delay(50);
   if(odczyt > 200)
   delay (10);
   delay (3000);
   while(digitalRead(7) == LOW);
Try again with this edit, what do you see in the serial monitor?
int odczyt;
while(!Serial) ;
   delay (3000); //
   delay(50);
   if(odczyt > 200)
   delay (10);
   delay (3000);
Try this, also what are you calling "laser".
int odczyt;
while(!Serial) ;
     digitalWrite(13,LOW);  //if button pushed
   delay (3000); //
   if(odczyt > 200)
   delay (10);
   delay (3000);
I need to make that function is working only for 3 seconds after button was pushed.
I am still not clear what you want to do.
Should some code (what code would that be ?) run for 3 seconds after the button becomes pressed or should there be a delay of 3 seconds after the button becomes depressed before the code runs ? If the latter, then how long should the code run ?
Something to get you started
const byte ledPin = 13;
const byte buttonPin = A1;
byte currentButtonState;
byte previousButtonState;
unsigned long currentMillis;
unsigned long previousMillis;
unsigned long buttonWaitInterval = 3000;
unsigned long blinkInterval = 500;
boolean blinking = false;
boolean timing = false;
unsigned long startTimingMillis;
unsigned long startBlinkMillis;
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT_PULLUP);
  Serial.println("Waiting for button press");
  currentMillis = millis();
  previousButtonState = currentButtonState;
  currentButtonState = digitalRead(buttonPin);
  if (!blinking && currentButtonState != previousButtonState && currentButtonState == LOW)  //LED not already blinking and button has become pressed
    if (!timing)    //not waiting for a button press
      Serial.println("Started waiting after button press");
      timing = true;
      startTimingMillis = currentMillis;  //save current time
  if (timing && currentMillis - startTimingMillis >= buttonWaitInterval)  //interval after button press has passed
    Serial.println("Started blinking LED");
    timing = false;
    blinking = true;
    startBlinkMillis = currentMillis;    //save time we started blinking LED
  if (blinking && currentMillis - startBlinkMillis >= blinkInterval)  //time to change stet of LED ?
    Serial.println("Blink");
    digitalWrite(ledPin, !digitalRead(ledPin));    //change LED state
    startBlinkMillis = currentMillis;              //save the time of change
It does not do exactly what you want but it will show you how to use millis() for timing.
