Program steppen motor
Hello,
I want to make a feeder for bags (school project)
I have a steppen motor with drive and i need a program to start and stop the motor.
The speed need to be fixed in the program.
im totally new to arduino so can someone help me?
I can use this wiring diagram ofcourse with start button.
im using this driver:
see attach
i have a Arduino Mega 2560
Thank you in advance !
Driver ZDM-2HA865 Manual Specification.pdf (653 KB)
These links may help
Stepper Motor Basics
Simple Stepper Code
also look up the AccelStepper library
...R
image missing and nobody will look at scribd.com for anything, so post the pdf.
Robin2:
Simple Stepper Code
...R
Thank you! i will look at it
Robin2:
Simple Stepper Code
...R
I have it working. i used your code.
What is prevStepMillis doing?
// testing a stepper motor with a Pololu A4988 driver board or equivalent
// this version uses millis() to manage timing rather than delay()
// and the movement is determined by a pair of momentary push switches
// press one and it turns CW, press the other and it turns CCW
byte directionPin = 9;
byte stepPin = 8;
byte buttonCWpin = 10;
byte buttonCCWpin = 11;
boolean buttonCWpressed = false;
boolean buttonCCWpressed = false;
byte ledPin = 13;
unsigned long curMillis;
unsigned long prevStepMillis = 0;
unsigned long millisBetweenSteps = 25; // milliseconds
    Serial.println("Starting Stepper Demo with millis()");
    pinMode(directionPin, OUTPUT);
    pinMode(stepPin, OUTPUT);
    pinMode(ledPin, OUTPUT);
    pinMode(buttonCWpin, INPUT_PULLUP);
    pinMode(buttonCCWpin, INPUT_PULLUP);
   curMillis = millis();
   readButtons();
   actOnButtons();
void readButtons() {
   if (digitalRead(buttonCWpin) == LOW) {
       buttonCWpressed = true;
   if (digitalRead(buttonCCWpin) == LOW) {
       buttonCCWpressed = true;
void actOnButtons() {
   if (buttonCWpressed == true) {
       digitalWrite(directionPin, LOW);
       singleStep();
   if (buttonCCWpressed == true) {
       digitalWrite(directionPin, HIGH);
       singleStep();
void singleStep() {
   if (curMillis - prevStepMillis >= millisBetweenSteps) {
           // next 2 lines changed 28 Nov 2018
       //prevStepMillis += millisBetweenSteps;
       prevStepMillis = curMillis;
       digitalWrite(stepPin, HIGH);
       digitalWrite(stepPin, LOW);
wasbever:
It records the time when the previous step happened.
...R
PS ... When posting code please use the code button </>
so your code
looks like this
and is easy to copy to a text editor See How to use the forum
