Program Storage Space Error
Hello All,
I am getting the following error message:
Sketch uses 3258 bytes (10%) of program storage space. Maximum is 30720 bytes.
Global variables use 232 bytes (11%) of dynamic memory, leaving 1816 bytes for local variables. Maximum is 2048 bytes.
Any help appreciated. The project I am trying to work on is an Upcycled RC Car off of Instructables. I copy and pasted the code. I tried to load it on a Nano and a Mega. Here is is:
#define ENABLE1 3 // Connect to pin 1 of chip (Needs to be PWM pin)
#define DIRA1 4 // Connect to pin 2 on L293D (Can be any I/O pin)
#define DIRB1 5 // Connect to pin 7 on L293D (Can be any I/O pin)
//Define pins for other motor
#define ENABLE2 6 // Connect to pin 9 on L293D (Needs to be PWM pin)
#define DIRA2 7 // Connect to pin 10 on L293D (Can be any I/O pin)
#define DIRB2 8 // Connect to pin 15 on L293D (Can be any I/O pin)
#define Buzzer 14 //Buzzer to analog pin 0
//For NRF module (radio):
#include <SPI.h> //Import SPI library
#include "RF24.h" //Import RF24 library
RF24 myRadio (9, 10); //These can be any I/O pins. Connect to (CE, CSN) respectively
byte addresses[][6] = {"0"};
//The following are only applicable to Arduino Nano:
//Connect MOSI to pin 11
//Connect MISO to pin 12
//Connect SCK to pin 13
//Connect IRQ to pin 2
struct package //data package that will be sent
int Speed;
int xCord;
int yCord;
int varPot;
package data;
int power;
int Delta;
int Theta;
int Speed;
int Turn;
int Direction;
int varPot;
//Define pinmode:
pinMode(ENABLE1, OUTPUT);
pinMode(DIRA1,OUTPUT);
pinMode(DIRB1,OUTPUT);
pinMode(ENABLE2, OUTPUT);
pinMode(DIRA2,OUTPUT);
pinMode(DIRB2,OUTPUT);
pinMode(Buzzer, OUTPUT);
//Setup radio
myRadio.begin();
myRadio.setChannel(115);
myRadio.setPALevel(RF24_PA_MAX); //Set NRF24L01+ to max current draw
myRadio.setDataRate( RF24_250KBPS ) ; //Set data rate to 250KBPS (for longest range)
myRadio.maskIRQ(1, 1, 0); //set NRF24L01+ to inturuppt only when data is recieved
myRadio.openReadingPipe(1, addresses[0]);
myRadio.startListening();
attachInterrupt(0,ReadRadio,FALLING); //Interrupt to read radio when NRF24L01 is recieving data. 0 is for pin 2
delay(10);
//Serial.println(map(abs(Speed), 0, 1024, 0, 255)
if (Speed > 75){
power = map(abs(Speed), 0, 1024, 100, 255); //The motor starts to rotate after a certain voltage threshold is hit. Therefore, when speed =! 0, we start at the voltage threshold value
//Serial.println(power);
Forward(power);
else{
Stop();
if (Turn < -3){ //Sometimes there is noise when reading the analog joysticks. Thats why we start turning when the Turn value is above +-3
    Delta = map(abs(Turn), 0, 499, 120, 255);
    Left(Delta);
   /* Serial.print("\n");
    Serial.println("Turning Left:");
    Serial.println(Delta); */
  else if (Turn > 3){
    Theta = map(abs(Turn), 0, 524, 120, 255);
    Right(Theta);
    /*Serial.print("\n");
    Serial.println("Turning Right:");
    //Serial.println(Theta); */
  else{
     NoTurn();
void ReadRadio(){
if ( myRadio.available()) //Check if radio is available
myRadio.read(&data, sizeof(data));
//For testing reasons:
/* Serial.print("\nPackage:");
Serial.print("x-Cord:");
Serial.print(data.xCord);
Serial.print("\n");
Serial.print("y-Cord:");
Serial.print(data.yCord);
Serial.print("\n");
Serial.print("Speed:");
Serial.print(data.Speed);
Serial.print("\n");
Serial.print("Var Pot:");
Serial.print(data.varPot);
Serial.print("\n"); */
else {
Serial.print("Radio was not avaliable");
Stop();
NoTurn();
return;
/Serial.println(Direction);
Serial.println(Turn);
Serial.println(Speed);
Direction = data.yCord - 508;
Turn = data.xCord - 499;
Speed = data.Speed;//allows for very fine control on speed
/* NOTE: Never turn on DIRA and DIRB at the same time. This will short the motor driver and it will go up in flames!*/
void Forward(int Speed){ //pass in the speed
analogWrite(ENABLE2, Speed); //go forward at this speed
digitalWrite(DIRA2,LOW);
digitalWrite(DIRB2,HIGH);
delay(1); //slight delay is needed
void Backward(int Speed){
digitalWrite(DIRA2,HIGH);
digitalWrite(DIRB2,LOW);
delay(1);
void Stop(){
digitalWrite(ENABLE2, LOW);
delay(1);
void NoTurn(){
digitalWrite(ENABLE1, LOW); //Reset steering
digitalWrite(DIRA1,LOW);
digitalWrite(DIRB1,LOW);
delay(1);
void Right(int tRadius){
analogWrite(ENABLE1, tRadius); //Turn right
digitalWrite(DIRB1,HIGH);
delay(1);
void Left(int tRadius){
analogWrite(ENABLE1, tRadius); //Turn left
digitalWrite(DIRA1,HIGH);
delay(1);
Thats a status message, not an error.
Please use the </> option to format your code.
just did some more troubleshooting. I tried to upload another code onto the Arduino Nano, without success. However, when I tried to load the same code onto the Arduino Uno, it was successful, as was the RC Code I initially posted. I checked each time to ensure I had the correct board selected under "Tools". could the problem be with the cable I am using to connect to the Nano itself? It does not appear my computer is reading it
Arduino Nano Drivers for Windows 10 - Using Arduino / Installation & Troubleshooting - Arduino Forum
Neither limit is being exceeded, what is your actual error?
The boards generally will show on different ports even if the same cable is used.
I see a comment about not turning on the motor in both directions at once and i have a suggestion. Instead of two io's, one fwd and one rev, rethink your design to use fwd/rev and go/stop. same two io's but impossible to command to burn up. It may require the addition of a 74x00 quad NAND gate to implement, but will never burn up from that particular error.
