So Im trying to build a controller for my airconditioning motor... The idea is that normally its shut down, but with a press of a button it starts to cycle between few different options.
First Push of a Button (later just PB) will activate the first program, which will drive the motor with about 10% for the next 6h.
With PB the second program will activate and the motor speed is increased to about 50% and it will hold it as long as it reaches a specific humidity.
The third PB (which seems also to be the problem) should shutdown the engine and run shutdown script (clearing the lcd and the the motorstate to idle)
For some reason the program gets stuck on the third step, and not going to IDLE mode. And I cannot seem to figure out why! It starts nicely on IDLE, then first button sets it to the timer more, second press to enhanced mode... but the third press, or any other that, just keeps it on shutdown mode not progressing to idle as it shoudl...
Most of it is coded with chatgpt, so it might look funny! Thanks and sorry in advance:
#include <DHT.h>
#include <Wire.h>
#define DHTPIN 2
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
const int numReadings = 60;
float humidityReadings[numReadings];
int index = 0;
const int buttonPin = 7;
int buttonState = 0;
int lastButtonState = 0;
unsigned long lastDebounceTime = 0;
unsigned long debounceDelay = 20;
const int motorPin = 9;
bool motorActive = false;
LiquidCrystal_I2C lcd(0x27, 16, 2);
enum State {
IDLE,
MOTOR_START_10,
MOTOR_START_50,
SHUTDOWN,
State currentState = IDLE;
unsigned long motorStartTime = 0;
unsigned long lastMotorToggleTime = 0;
float meanHumidity = 0;
volatile unsigned int pulseCount = 0;
unsigned long lastPulseTime = 0;
Serial.println("DHT22 Humidity and Temperature Sensor");
pinMode(buttonPin, INPUT_PULLUP);
pinMode(motorPin, OUTPUT);
dht.begin();
lcd.init();
lcd.backlight();
lcd.clear();
attachInterrupt(digitalPinToInterrupt(3), handlePulse, FALLING); // Assuming pulse input is connected to digital pin 3
meanHumidity = 30;
Serial.println("Loop In...");
float humidity = dht.readHumidity();
float temperature = dht.readTemperature();
if (isnan(humidity) || isnan(temperature)) {
Serial.println("Failed to read from DHT sensor!");
return;
humidityReadings[index] = humidity;
index = (index + 1) % numReadings;
if (index == 0) {
meanHumidity = calculateMeanHumidity();
Serial.print("Mean Humidity (excluding last 3 hours): ");
Serial.print(meanHumidity);
Serial.println("%");
displayHumidityTemperature(humidity, temperature);
Serial.println("Delaying for 1 second...");
Serial.println(currentState);
int reading = digitalRead(buttonPin);
if (reading != lastButtonState) {
lastDebounceTime = millis();
// Serial.println(buttonPin);
if ((millis() - lastDebounceTime) > debounceDelay) {
if (reading != buttonState) {
buttonState = reading;
if (buttonState == LOW) {
Serial.println("Button pressed!");
// Handle button press based on current state
switch (currentState) {
case IDLE:
currentState = MOTOR_START_10; // Timer with 10% and 6h
motorStartTime = millis();
Serial.println("Ajastus");
case MOTOR_START_10:
currentState = MOTOR_START_50; // Enhanced state with 50% power and humidity target
Serial.println("Tehostus");
case MOTOR_START_50:
currentState = SHUTDOWN; // Shutting down the program
Serial.println("Shutdown...");
// Handle state transitions
analogWrite(motorPin, 55); // 10% duty cycle, about 1V
if (millis() - motorStartTime >= 6 * 3600 * 1000) { // 6 hours in milliseconds
currentState = SHUTDOWN; // If the motor has been running for 6 hours, shut down
Serial.println("1 toimii!");
analogWrite(motorPin, 140); // 25% duty cycle, about 2,5V
float currentHumidity = dht.readHumidity();
if (currentHumidity <= (meanHumidity - 5)) { // If current humidity is at or below above mean humidity, shut down
Serial.println("2 toimii!");
Serial.println("vielä toimii");
case SHUTDOWN:
// Perform any necessary shutdown tasks
// For example, saving data to memory, closing connections, etc.
// Then, turn off the motor and LCD
Serial.println("idle...?");
analogWrite(motorPin, 0);
lcd.clear();
delay(50); // Lisää lyhyt viive
if (digitalRead(buttonPin) == HIGH) { // Check if button is released before transitioning back to IDLE
case IDLE:
// Perform any tasks in the idle state if needed
lastButtonState = reading;
Serial.println("Loop Out...");
float calculateMeanHumidity() {
float sum = 0;
// Calculate the sum of all humidity readings
for (int i = 0; i < numReadings; i++) {
sum += humidityReadings[i];
// Calculate the mean humidity over the entire period
float meanHumidity = -1; // Initializing the mean humidity
if (numReadings > 0) {
meanHumidity = sum / numReadings;
// Exclude the latest 3 hours of readings
int startIndexToExclude = (index - 3 * 60 + numReadings) % numReadings; // Calculate the index of the first reading to exclude
for (int i = index; i != startIndexToExclude; i = (i + 1) % numReadings) {
meanHumidity -= humidityReadings[i] / numReadings;
return meanHumidity;
void displayHumidityTemperature(float humidity, float temperature) {
lcd.clear();
lcd.setCursor(0, 0);
// Display humidity on LCD
char humidityStr[3];
dtostrf(humidity, 3, 0, humidityStr);
lcd.print("RH:");
lcd.print(humidityStr);
lcd.print("%");
// Display temperature on LCD
lcd.setCursor(8, 0);
char temperatureStr[4];
dtostrf(temperature, 4, 1, temperatureStr);
lcd.print("T:");
lcd.print(temperatureStr);
lcd.print("C");
// Display fan RPM on lower row
lcd.setCursor(0, 1);
lcd.print("RPM:");
lcd.print(getFanRPM(), 0); // Display RPM as integer
// Display mode on lower right corner
lcd.setCursor(8, 1);
lcd.print("AJASTUS");
lcd.print("TEHOSTUS");
void handlePulse() {
unsigned long currentTime = micros();
unsigned long pulseWidth = currentTime - lastPulseTime;
// Check if the pulse width is valid (to avoid erroneous pulses)
if (pulseWidth > 1000 && pulseWidth < 50000) {
pulseCount++;
lastPulseTime = currentTime;
float getFanRPM() {
// Assuming pulseCount increments for every revolution
// Calculate RPM based on the time between pulses
unsigned long currentTime = millis();
unsigned long elapsedTime = currentTime - lastMotorToggleTime;
if (elapsedTime >= 60000) { // Update RPM every minute
float rpm = (float)pulseCount / (elapsedTime / 60000.0);
pulseCount = 0;
lastMotorToggleTime = currentTime;
return rpm;
return 0; // Return 0 if RPM calculation interval hasn't passed yet
