Hello,
I am using the code found in the following website to implement a 1MSPS oscilloscope on the Arduino Due:
This code works beautifully (no errors, warnings, etc). However, ~7 min 40 sec into the code running, it just stops running. I ran it 3 times and came up with the exact same time. I have not touched the computer, no errors are displayed, there is not a time limit in the code that I can see. In order to get the program to run again, I need to press the reset button on the Due and rebuild the python script.
What would cause the code to all of a sudden stop working? Is there a limit to the number of loop iterations in the Due? Is there a limit to the number of iterations in python?
I have tried removing all code pertaining to exiting in the Python code, yet the issue persists. Any advice is appreciated.
