I apologize upfront for my ignorance. I am attempting to automate the blast gates in my shop by using an arduino. I would like to control the arduino with an IR control and have it in turn control an 8 channel relay. Relay will be connected to individual pneumatic solenoids.
I am just an older guy who likes to putter around and make things.
That is it. The solenoids are 24 volts. What I would like to find initially, is the program that will allow the arduino to turn the relays off and on. The IR part would be my next venture.
I really appreciate your help and patience. It has been may years since I took physics.
Open to any ideas/suggestions. I have about 4-5 blast gates that will be operated using 5 valve/2 way pneumatic solenoids. Solenoids are 24 volt DC. Ideally I would like to be able to use an IR control to open and close each gate individually.
As mentioned, we need to know how big the solenoids are.
The right solution depends on the current draw of the solenoids.
Do you have a link to them, or do you know the resistance of the coils.
IR control is a different problem, but not that hard to add.
Leo..
#include "IRremote.h"
//LarryD
//Sketch to demonstrate using an IR hand remote to control Arduino outputs.
//The remote used here uses the NEC protocol.
//This remote sends the button code (example 0xFF629D) then a repeat code 0xFFFFFFFF
//The repeat code is re-sent as long as an IR remote button is pressed.
//The IR receiver used is the TSOP4838
/* 17 IR button remote layout http://i.imgur.com/X1KIdqI.png
< OK >
v
1 2 3
4 5 6
7 8 9
* 0 #
const byte RECV_PIN = 7; //IR receive pin
IRrecv irrecv(RECV_PIN); //create instance of 'IRrecv'
decode_results results; //create instance of 'decode_results'
unsigned long TimerUp; //UP arrow on the remote
boolean TimerUpFlag = false;
unsigned long TimerDown; //DOWN arrow on the remote
boolean TimerDownFlag = false;
unsigned long TimerIntensity;
unsigned long TimerIncDec;
boolean intesityUpFlag = false;
boolean intesityDownFlag = false;
int brightness;
unsigned long dummy;
unsigned long * TimerPtr = &dummy; //pointer to the current timer
const byte upLED = 13; //turns on as long as the UP button is pressed
const byte downLED = 12; //turns on as long as the DOWN button is pressed
const byte leftLED = 11; //toggles on/off
const byte rightLED = 10; //toggles on/off
const byte intensityLED = 9; //a LED which can have its intensity adjusted
// s e t u p ( )
irrecv.enableIRIn(); //start receive
pinMode(upLED, OUTPUT);
pinMode(downLED, OUTPUT);
pinMode(leftLED, OUTPUT);
pinMode(rightLED, OUTPUT);
pinMode(intensityLED, OUTPUT); //this is a PWM output pin
} // E N D O F s e t u p ( )
// l o o p ( )
if (irrecv.decode(&results)) //is there IR remote button code
//Serial.println(results.value);
processButton(); //process button press
irrecv.resume(); //restart for next button press
//********************** //Turn off upLED
//if timing is enabled, is it time to stop
if (TimerUpFlag && millis() - TimerUp >= 250ul)
TimerUpFlag = false; //disable timing
TimerPtr = &dummy; //pointer to dummy timer
digitalWrite(upLED, LOW);
//********************** //Turn off downLED
if (TimerDownFlag && millis() - TimerDown >= 250ul)
TimerDownFlag = false; //disable timing
digitalWrite(downLED, LOW);
//********************** //LED intensity
//are we still within the adjustment time
if (millis() - TimerIntensity <= 300ul)
//is it time to increase/decrease the intensity
if (millis() - TimerIncDec >= 200ul)
TimerIncDec = millis();
if (intesityUpFlag == true) //Increase
brightness += 5;
if (brightness > 255)
brightness = 255;
else if (intesityDownFlag == true) //Decrease
brightness -= 5;
if (brightness < 0)
brightness = 0;
analogWrite(intensityLED, brightness);
//Serial.println(brightness); //debug
//stop increasing/decreasing intensity
//Other non blocking code goes here
} // E N D O F l o o p ( )
// F U N C T I O N S
// p r o c e s s B u t t o n ( )
//process IR remote button presses
void processButton()
switch (results.value)
case 0xFF629D: //UP Arrow
Serial.println("UP");
TimerPtr = &TimerUp; //point to this timer
TimerUpFlag = true; //enable timing
digitalWrite(upLED, HIGH);
TimerUp = millis();
case 0xFFA857: //DOWN Arrow
Serial.println("DOWN");
TimerPtr = &TimerDown; //point to this timer
TimerDownFlag = true; //enable timing
digitalWrite(downLED, HIGH);
TimerDown = millis();
case 0xFF22DD: //LEFT Arrow
Serial.println("LEFT");
digitalWrite(leftLED, !digitalRead(leftLED)); //Toggle LED
case 0xFFC23D: //RIGHT Arrow
Serial.println("RIGHT");
digitalWrite(rightLED, !digitalRead(rightLED)); //Toggle LED
case 0xFF42BD: // * button
Serial.println("*");
TimerPtr = &TimerIntensity; //point to this timer
intesityUpFlag = true; //enable intensity up adjustment
TimerIntensity = millis();
case 0xFF52AD: // # button
Serial.println("#");
intesityDownFlag = true; //enable intensity down adjustment
case 0xFF02FD:
Serial.println("OK");
case 0xFF6897:
Serial.println("1");
case 0xFF9867:
Serial.println("2");
case 0xFFB04F:
Serial.println("3");
case 0xFF30CF:
Serial.println("4");
case 0xFF18E7:
Serial.println("5");
case 0xFF7A85:
Serial.println("6");
case 0xFF10EF:
Serial.println("7");
case 0xFF38C7:
Serial.println("8");
case 0xFF5AA5:
Serial.println("9");
case 0xFF4AB5:
Serial.println("0");
case 0xFFFFFFFF: //Repeat code
Serial.println("REPEAT");
*TimerPtr = millis(); //reset the current timer
} // END switch case
} // E N D o f p r o c e s s B u t t o n ( )
// E N D O F C O D E
