Program Update to Arduino Nexus Board hangs
Hello,
I have problems uploading basic programs to the Arduino 328 Controller board with the ATmega328p Controller. Compiling works, but the uploading process does not end...I have tested changing the Board selection in the Configuration in the settings, as well as processor, but nothing changed. The serial port is the right one.
I have tested it with the last arduino environment as well with the 1.6.9 release.
Does anyone have a similar problem?
The console output is:
Sketch uses 928 bytes (3%) of program storage space. Maximum is 30,720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
C:\Users\Lev\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\Lev\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b57600 -D -Uflash:w:C:\Users\Lev\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Lev\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 57600
Thanks in advance!
leviathan1234:
What are you talking about?
