Hey. I'm trying to use arduino with Bluetooth module (HC-06).
And also im trying to send/receive data from android with the app (ArduDroid which is in playstore).
But i have the problem while sending program to Arduino uno after successful compilation.
The error Code is when vcc connected to 3.3V
avrdude: stk500_getsync(): not in sync: resp=0x00
When i connected to 5V sometimes error code changes to but usually same as 3.3v
avrdude: stk500_getsync(): not in sync: resp=0x45.
When i unplug the bt device sending program is successful but i cant receive or send anything.
I checked com port and board. Everything is OK.
Please help me to continue my licence project.
Best regards..
The code is as below:
int ledPin = 13;
int state = 0;
int flag = 0;
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
Serial.begin(9600); // Default connection rate for my BT module
if(Serial.available() > 0){
state = Serial.read();
flag=0;
if (state == '0') {
if(flag == 0){
Serial.println("LED: off");
flag = 1;
else if (state == '1') {
digitalWrite(ledPin, HIGH);
if(flag == 0){
Serial.println("LED: on");
flag = 1;
Unplug the device. Upload the code. Reattach the device. Is that so difficult a concept?
I already done what you said a lot of time as i wrote in the question. Firstly read it again and answer again next time.
I solved the problem and i did the same steps as before and its ok but sometimes it doesn't work.
I'll check the system again.
I'm not sure if it's the same for a Uno, but with my Mega, I can plug a HC-05 (JY-MCU 1.06) on RX0/TX0 and still be able to upload sketch by USB cable.
It does not work with HC-07 (JY-MCU 1.05), and to be honest I have no idea why it's working with HC-05...
As I said unplug the vcc cable from bread board(for bluetooth device) then upload your code. Check the bt device's led should be of. then finishing upload connect again your bt device to the vcc. that's okay your circuit is working
Hi
I am doing project of bluetooth control car with Arduino UNO unfortunately I have forgotten to unplug the bluetooth and the IDE shows the error after I unplugged the bluetooth I did the same the IDE shows errors
And I did it multiple times I don't know what to do..
