i had done program for rummy card dealer which can distributes rummy card according to no of players and no of cards
i am using A4988,keypad,16x2 lcd and DC motor when i run it in arduino uno that runs fine but if i run it in esp32 or esp8266 it not run instead of run it returns Watchdog timer error
v00043350
~ld
����o�{��o<�$�l b�e�<s�l�o��o�l��r�$�d��
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x4010f000, len 3424, room 16
tail 0
chksum 0x2e
load 0x3fff20b8, len 40, room 8
tail 0
chksum 0x2b
csum 0x2b
v00043350
~ld
please answer anybody knows how can solve it
//Programa: Display LCD 16x2 e modulo I2C
//Autor: Arduino e Cia
#include <Wire.h>
#include <Keypad.h>
int player[2];
int numcard[2];
char key,ke;
int i=0;
int c;
int a;
int x=0;
int z=0,y=0;
const byte ROW_NUM = 4;
const byte COLUMN_NUM = 4;
const int steppin=3;
const int dirpin=2;
char keys[ROW_NUM][COLUMN_NUM] = {
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
byte pin_rows[ROW_NUM] = {6, 7, 8, 9};
byte pin_column[COLUMN_NUM] = {10, 11, 12, 13};
Keypad myKeypad = Keypad(makeKeymap(keys), pin_rows, pin_column, ROW_NUM, COLUMN_NUM);
// instancias
LiquidCrystal_I2C lcd(0x27, 16, 2);
void cl()
if(key=='C'&&i<=3)
for(int f=0;f<2;f++)
player[f]=0;
numcard[f]=0;
i=0;
x=0;
lcd.setCursor(0,1);
lcd.print(" ");
Serial.print("Player,i=0");
else if(ke=='C'&&x<=3&&i<4)
for(int g=0;g<2;g++)
numcard[g]=0;
//i=0;
x=0;
lcd.setCursor(0,1);
lcd.print(" ");
Serial.print("Card,x=0");
void clean()
y=0;
z=0;
i=0;
x=0;
lcd.init();
lcd.clear();
lcd.init();
lcd.setBacklight(HIGH);
/* lcd.setCursor(0,0);
lcd.print("Enter Number:");*/
pinMode(steppin,OUTPUT);
pinMode(dirpin,OUTPUT);
pinMode(4,OUTPUT);
lcd.setCursor(0,0);
lcd.print("No of Players:");
// lcd.setCursor(0,0);
//lcd.print("No of Players:");
key = myKeypad.getKey();
if (key) {
if(key=='C')
cl();
Serial.println("KEY");
player[f]=0;
numcard[f]=0;
else if(key=='C'&&x<2&&i==2)
numcard[g]=0;
else if(key=='A'||key=='B'||key=='D')
lcd.setCursor(0,1);
lcd.print("INVALID");
clean();
else if(key=='#')
lcd.init();
lcd.clear();
lcd.setCursor(0,0);
lcd.print("No of cards");
while(x<2){
ke=myKeypad.getKey();
if(isDigit(ke)){
lcd.setCursor(0,1);
lcd.print(ke);
numcard[x]=ke;
x++;
Serial.println(x);
if(x==2)
lcd.setCursor(0,1);
a=(numcard[0]-'0')*10+numcard[1]-'0';
lcd.print(a);
Serial.println("Cardarray");
else if(ke=='C')
cl();
Serial.println("CARD");
else if(ke=='A'||key=='B'||key=='D')
lcd.setCursor(0,1);
clean();
lcd.setCursor(0,0);
else if(key=='*')
motor(c,a);
else if(isDigit(key))
lcd.setCursor(0, 1);
lcd.print(key);
player[i]=key;
i++;
Serial.println(i);
if(i==2)
//lcd.clear();
lcd.setCursor(0,1);
c=(player[0]-'0')*10+player[1]-'0';
lcd.print(c);
// delay(1000);
i++;
Serial.println("Playerarray");
void motor(int per,int card)
//int per;
//int card;
int ang=360/per;
int pulse=ang/1.8;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("PROCESSING");
for(y=0;y<per*card;y++){
for(z=0;z<pulse;z++)
digitalWrite(dirpin,LOW);
digitalWrite(steppin, HIGH);
delayMicroseconds(550);
digitalWrite(steppin,LOW);
//digitalWrite(4, LOW);
start();
digitalWrite(4,LOW);
y=0;
z=0;
i=0;
x=0;
lcd.clear();
lcd.setCursor(0,0);
void stop(){
delay(300);
void start(){
digitalWrite(steppin, LOW);
digitalWrite(4, HIGH);
delay(350);
delay(550);
