program uploading error
i am using a dccduino( arduino uno clone) the driver ch340 is succesfully installed and the port was also correctly selected but still the following error is coming while uploading the blink example.
Arduino: 1.6.5 (Windows 7), Board: "Arduino Uno"
Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x54
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x04
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x10
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x54
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
enabled in File > Preferences.
I suggest trying the loop back test, which is described in one of the messages tacked at the top of this installation and troubleshooting forum.
You can also try setting Tools, Board to Arduino Duemilanove or Diecimila to see if you have the bootloader which operates at 57600 baud.
please help me resolve this error
Arduino: 1.6.5 (Windows XP), Board: “Arduino Uno”
C:\devansh\arduino-1.6.5-r2\hardware\tools\avr/bin/avrdude -CC:\devansh\arduino-1.6.5-r2\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\DOCUME~1\SMK~2.PSE\LOCALS~1\Temp\build8779990472261621126.tmp/Blink.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is “C:\devansh\arduino-1.6.5-r2\hardware\tools\avr/etc/avrdude.conf”
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x50
Hardware Version: 3
Firmware Version: 2009155088.4
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x03
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 0.050 Hz
SCK period : 2180221271.8 us
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x03
this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
avrdude done. Thank you.
“Show verbose output during compilation”
devanshkhandekar:
Perhaps you should contact the makers of that board and use their technical support service.
