Program used to log data will not log data into text file
Hi! So I coded a program to log data from a sensor to a text file, but it won’t work and the data is not being logged into the text file. The Serial monitor outputs the data right, but it won’t appear in the text file. The text file is just blank when I run this code.
Code
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
const int chipSelect = 10;
int sensor = 0;
File logfile;
String dataString;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  pinMode(10, OUTPUT);
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    while (1);
  Serial.println("card initialized.");
  String dataString = "";
  sensor = analogRead(A0);
  dataString += String(sensor);
  File logfile = SD.open("datalog.txt", FILE_WRITE);
  if (logfile) {
    Serial.println(dataString);
    logfile.println(dataString);
    logfile.close();
  else {
    Serial.println("can't access file");
I don’t really know what I am doing so help would be greatly appreciated.
Thanks!
Welcome to the forum!
What Arduino board do you use?
What size has the SD card?
The code you show does not compile.
The code looks quite similar to the code used as example for the data logger shield (but missing some lines):
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
int sensor = 0;
  while (!Serial) {
    while (1);
  if (logfile) {
    logfile.close();
  else {
  delay(5000);
When I run this code with my data logger shield mounted on an Arduino UNO, I get the expected results (file “datalog.txt” with sensor data).
Show your complete code please.
