Program will create a file on SD but will not write to it
As the title says, my code will create a file, when i push a button it will execute an if statement to close the file and print done. However when i open the file on the laptop it is empty. Setup is as follows;
genuine arduino uno R3
genuine arduino ethernet shield with SD
sandisk 16Gb class 10 microSD
ptm button;
arduino - breadboard
5V to button
button to ground
10K resistor connected between between button and ground
so connected like in the link below;
below is my code;
#include <SPI.h>
#include <SD.h>
File myFile;
const int buttonPin = 3;     // the number of the pushbutton pin
int buttonState = 0;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  pinMode(buttonPin, INPUT);
  myFile = SD.open("BUTTON.txt", FILE_WRITE);
  buttonState = digitalRead(buttonPin);
  if (myFile) {
  Serial.println(millis());
 if ( buttonState == HIGH) {
        // close the file:
    myFile.close();
    Serial.println("done.");
    delay(5000);
i have had this card working before but now it wont work. I have tried a a separate module, a kingston 32Gb class 4 SD, powering the module with 3.3V and 5V.
When i run it, it gives me the time in milliseconds, but when i press the button it stops the code, writes “done”, but will not have saved it, though it obviously has gone through the if statement to write “done”. I know it will be something simple but i just cant see it.
Thanks
I don't see where you actually write anything to the file.
Should that be?
myFile.print(millis());
well that would be it...thankyou. Been up all night trying to sort everything out for an experiment today. More sleep is needed!
Sometimes a fresher pair of eyes...
