Program works on Mega, not on Uno (ethernet shield)
I don't remember what I added to the program to cause it to stop working on the Uno, but earlier, simpler versions of the program worked, the latest breaks the networking (No ping or TCP/IP connections). Note, the card indicates ethernet hardware activity.
Here's the code:
#include <SPI.h>
#include <Ethernet.h>
#include <stdio.h>
float aatof(char* str);
char IDN_resp[] = "DGH Bias/Filament Supply";
char CMD_buf[64], RESP_buf[64], CMD[4][25],  buf_c, f_str[16];
int i, j, n;
float volts;
// Power Supply configuration
struct {
  char  Name[16];
  int  EnablePin;
  int  SetPin;
  float  SetScale;
  int SensorPin;
  float  SensorScale;
  float  SetValue;
  float  PValue;
} PS[] = {{"N48V", -1, 5, 256/50, A0, 1.0, 15.0, 0.0}, {"N8V", 4, 6, 256/7.5, A1, 1.0, 6.3, 0.0}};
int nSupplies = 2, selSupply = 0;
// network configuration.  gateway and subnet are optional.
 // the media access control (ethernet hardware) address for the shield:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
//the IP address for the shield:
byte ip[] = { 192, 168, 1, 41 };
// the router's gateway address:
byte gateway[] = { 192, 168, 1, 1 };
// the subnet:
byte subnet[] = { 255, 255, 0, 0 };
// use port 40, but you may use telnet port 23
EthernetServer server = EthernetServer(40);
  // set pins as PWM outputs
  for (i=0; i<nSupplies; i++) { pinMode(PS[i].SetPin, OUTPUT); }
  // initialize the ethernet device
  Ethernet.begin(mac, ip, gateway, subnet);
  // start listening for clients
  server.begin();
  // if an incoming client connects, there will be bytes available to read:
  if (client == true) {
    i = 0;
    while ((buf_c = client.read()) != -1 ) {CMD_buf[i++] = toupper(buf_c);}
    CMD_buf[i++] = 0;
    if (strncmp(CMD_buf, "*IDN?", 5) == 0) {client.println(IDN_resp); goto bailout;}
    if (sscanf(CMD_buf, "%[^:\ ]:", CMD[0]) <0) client.println("Command not found\n");
    else if (strncmp(CMD[0], "INST", 4) == 0) {
        if (sscanf(CMD_buf, "%*[^:\ ] :%[^:\n]", CMD[1]) <0) client.println("Command not found\n");
	if (strncmp(CMD[1], "NSEL", 4) == 0) {
	  if (sscanf(CMD[1], "NSEL%s\n", CMD[2]) >0) {
	    switch (CMD[2][0]) {
	      case '?': sprintf(RESP_buf, "%d\n", selSupply+1); client.println(RESP_buf); break;
	      case '1':
	      case '2': selSupply = CMD[2][0] - 49; break;
	      default: sprintf(RESP_buf, "bad command\n"); client.println(RESP_buf); break;
	  goto bailout;
	if (strncmp(CMD[1], "SEL", 3) == 0) {
	  if (sscanf(CMD[1], "SEL%s\n", CMD[2]) >0) {
	      case '?': sprintf(RESP_buf, "%s\n", PS[selSupply].Name); client.println(RESP_buf); break;
	      default:
		j = 1;
		for (i=0; i<nSupplies; i++) {if (strcmp(CMD[2], PS[i].Name) == 0) {selSupply = i; j = 0; break;}}
		if (j) {sprintf(RESP_buf, "bad command\n"); client.println(RESP_buf); break;}
	  goto bailout;
        sprintf(RESP_buf, "CMD[0] = %s, CMD[1]=%s\n", CMD[0], CMD[1]); client.println(RESP_buf);
        goto bailout;
    else if (strncmp(CMD[0], "VOLT", 4) == 0) {
	if (strncmp(CMD[1], "TRIG", 4) == 0) {
	  if (sscanf(CMD[1], "TRIG %[.0-9]\n", f_str) >=0) {PS[selSupply].SetValue = aatof(f_str); goto bailout;}
	if (strncmp(CMD[1], "IMM", 3) == 0) {
	  if (sscanf(CMD[1], "IMM %[.0-9]\n", f_str) >0) {PS[selSupply].SetValue = aatof(f_str); dtostrf(PS[selSupply].SetValue, 4, 2, f_str);
      sprintf(RESP_buf, "%s PS, %s V\n", PS[selSupply].Name, f_str); client.println(RESP_buf); goto bailout;}
        sprintf(RESP_buf, "VOLT CMD[0] = %s, CMD[1]=%s\n", CMD[0], CMD[1]); client.println(RESP_buf);
        goto bailout;
    if (strlen(CMD_buf) > 0) client.println("Command not found\n");
    bailout: CMD_buf[0] = 0; RESP_buf[0] = 0;
    for (i=0; i<nSupplies; i++) {analogWrite(PS[i].SetPin, PS[i].SetScale*PS[i].SetValue);}
    delay(100);
    for (i=0; i<nSupplies; i++) {PS[i].PValue = analogRead(PS[i].SensorPin)*1.5;}
    delay(100);
float aatof(char* str) {
  char fract[24];
  int i, j, fraction;
  sscanf(str, "%d.%s", &i, fract);
  sscanf(fract, "%d", &fraction);
  return (float) i + (float) fraction/pow(10, strlen(fract));
If the same code works on a Mega 2560 (8K SRAM) but doesn't work on an Uno (2K SRAM), it is normally due to running out of SRAM on the Uno.
Oh, sorry. I was confused because during compilation it reported memory usage at 17 KB/32 KB for the Uno, 19KB/256KB with the Mega.
Thanks. I read up on Arduino memory, it all makes sense now. I suppose I should use PROGMEM.
Do MACROS help? If I define a string as a MACRO, seems I should be able to use it like a variable, but the string itself should be stored in FLASH.
