I am trying to work on the NodeMcu. I use it to ping a cloud server to get data. While I use the same code on my home PC, the response times are much faster (~300-400 ms), while at work, it is close to ~5 s. I use the same hotspot for the internet etc.
One thing I observe is that the uploading parameters in the Arduino IDE I have at home is different from the IDE at work, even though they are the same version. (1.6.5). I think it is because of it being different revisions (?!). I downloaded the IDE at work from the Arduino website. The IDE I have at my home PC was installed a few years ago. ANy possible way I can get the older revisions from the Arduino website or elsewhere? I think the 1.6.5 version available right now is the r5 version (last update of the series).
abhir24:
Upload parameters will be determined by the ESP8266 Core for Arduino version you have installed, not the IDE version. You can check which ESP8266 Core version you have at Tools > Board > Boards Manager.
abhir24:
Although not listed on the downloads page, compiled builds of the Arduino IDE 1.6.5 and 1.6.5-r4 are available in addition to 1.6.5-r5 (you're correct that the download links point to 1.6.5-r5). You only need to modify the URL. For 1.6.5-r2 and 1.6.5-r3 you'd need to checkout that tag of the arduino/Arduino repository and then build from source, following these instructions:
Again, I'm skeptical that the IDE version is the source of the difference.
Thanks, @pert for the response. It wasn't the IDE version. I had to change the version of the board in the boards' manager. It works well now as it worked on the home laptop.
