program
Sir,
please help to guide for code...
In my loop, about 60 seconds motor is running, then it will turned off.
During the 60 seconds of motor ON, i want to show the elapsed time in the LCD display.
also i do not know the code for how to reset the millis() for next process to take the start time as zero .
Thanks.
You need to post your program if you want help with it.
The demo Several Things at a Time illustrates the use of millis() to manage timing. It may help with understanding the technique.
...R
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
What model Arduino are you using?
Thanks.. Tom.. :slight_smile:
samrajD:
Sir,
Thanks.
samrajBhai, show us what your code looks like. try the blink without delay in the arduino IDE examples. That should give you an idea from where to start.
