Programa con arduino
Buenas tardes;
soy un joven que esta iniciándose en esto del arduino, y ya tengo algunas dudas, como cabe esperar, jajajaj.
Mi propósito es conseguir que un motor se mueva a ciertas horas del día. Ya he comprado el DS1307, y he hecho el reloj. Hay os mando el programa.
// INCLUDE
#include <Wire.h> // For some strange reasons, Wire.h must be included here
#include <DS1307new.h>
// DEFINE
// VARIABLES
uint16_t startAddr = 0x0000; // Start address to store in the NV-RAM
uint16_t lastAddr; // new address for storing in NV-RAM
uint16_t TimeIsSet = 0xaa55; // Helper that time must not set again
// SETUP
pinMode(2, INPUT); // Test of the SQW pin, D2 = INPUT
digitalWrite(2, HIGH); // Test of the SQW pin, D2 = Pullup on
PLEASE NOTICE: WE HAVE MADE AN ADDRESS SHIFT FOR THE NV-RAM!!!
NV-RAM ADDRESS 0x08 HAS TO ADDRESSED WITH ADDRESS 0x00=0
TO AVOID OVERWRITING THE CLOCK REGISTERS IN CASE OF
ERRORS IN YOUR CODE. SO THE LAST ADDRESS IS 0x38=56!
RTC.setRAM(0, (uint8_t *)&startAddr, sizeof(uint16_t));// Store startAddr in NV-RAM address 0x08
Uncomment the next 2 lines if you want to SET the clock
Comment them out if the clock is set.
DON'T ASK ME WHY: YOU MUST UPLOAD THE CODE TWICE TO LET HIM WORK
AFTER SETTING THE CLOCK ONCE.
// TimeIsSet = 0xffff;
// RTC.setRAM(54, (uint8_t *)&TimeIsSet, sizeof(uint16_t));
Control the clock.
Clock will only be set if NV-RAM Address does not contain 0xaa.
DS1307 should have a battery backup.
RTC.getRAM(54, (uint8_t *)&TimeIsSet, sizeof(uint16_t));
if (TimeIsSet != 0xaa55)
RTC.stopClock();
RTC.fillByYMD(2011,4,8);
RTC.fillByHMS(22,7,0);
RTC.setTime();
TimeIsSet = 0xaa55;
RTC.startClock();
RTC.getTime();
Control Register for SQW pin which can be used as an interrupt.
RTC.ctrl = 0x00; // 0x00=disable SQW pin, 0x10=1Hz,
// 0x11=4096Hz, 0x12=8192Hz, 0x13=32768Hz
RTC.setCTRL();
Serial.println("DS1307 Testsketch");
Serial.println("Format is "hh:mm:ss dd-mm-yyyy DDD"");
uint8_t MESZ;
MESZ = RTC.isMEZSummerTime();
Serial.print("MEZ=0, MESZ=1 : ");
Serial.println(MESZ, DEC);
// MAIN (LOOP)
RTC.getTime();
if (RTC.hour < 10) // correct hour if necessary
Serial.print("0");
Serial.print(RTC.hour, DEC);
Serial.print(":");
if (RTC.minute < 10) // correct minute if necessary
Serial.print("0");
Serial.print(RTC.minute, DEC);
Serial.print(":");
if (RTC.second < 10) // correct second if necessary
Serial.print("0");
Serial.print(RTC.second, DEC);
Serial.print(" ");
if (RTC.day < 10) // correct date if necessary
Serial.print("0");
Serial.print(RTC.day, DEC);
Serial.print("-");
if (RTC.month < 10) // correct month if necessary
Serial.print("0");
Serial.print(RTC.month, DEC);
Serial.print("-");
Serial.print(RTC.year, DEC); // Year need not to be changed
Serial.print(" ");
switch (RTC.dow) // Friendly printout the weekday
case 1:
Serial.print("MON");
case 2:
Serial.print("TUE");
case 3:
Serial.print("WED");
case 4:
Serial.print("THU");
case 5:
Serial.print("FRI");
case 6:
Serial.print("SAT");
case 7:
Serial.print("SUN");
Serial.print(" seconds since 1.1.2000:");
Serial.print(RTC.time2000, DEC);
uint8_t MESZ = RTC.isMEZSummerTime();
Serial.print(" MEZ=0, MESZ=1 : ");
Serial.print(MESZ, DEC);
Serial.print(" - Address in NV-RAM is: ");
RTC.getRAM(0, (uint8_t *)&lastAddr, sizeof(uint16_t));
Serial.print(lastAddr, HEX);
lastAddr = lastAddr + 1; // we want to use it as addresscounter for example
RTC.setRAM(0, (uint8_t *)&lastAddr, sizeof(uint16_t));
if (TimeIsSet == 0xaa55) // check if the clock was set or not
Serial.println(" - Clock was set!");
Serial.println(" - Clock was NOT set!");
delay(1000); // wait a second
Que lógicamente lo he conseguido. Ahora no se como guardar el tiempo en real, para compararlo con el que yo quiero que gire y pare el motor. Me gustaría a ver si me pudierais ayudar.
Muchas gracias por adelantado.
Joaquín.
