Programa de "Decoder RAW IR" no consigo que funcione
Hola compañeros, pues estoy intentando hacer practicas con un modulo receptor de infrarrojos para saber de su funcionamiento para futuros proyectos. Dispongo de un arduino mega, y tengo la conexion realizada de la siguiente forma, de izquierda a derecha: 1--> datos en el pin 2, 2-->GND, 3-->5v. Cargo el siguiente programa y no me hace nada, alguien sabe la causa?? Gracias
#include <IRremote.h>
#include <IRremoteInt.h>
/* Raw IR decoder sketch!
 This sketch/program uses the Arduno and a PNA4602 to
 decode IR received. This can be used to make a IR receiver
 (by looking for a particular code)
 or transmitter (by pulsing an IR LED at ~38KHz for the
 durations detected
 Code is public domain, check out www.ladyada.net and adafruit.com
 for more tutorials!
// We need to use the 'raw' pin reading methods
// because timing is very important here and the digitalRead()
// procedure is slower!
//uint8_t IRpin = 2;
// Digital pin #2 is the same as Pin D2 see
// http://arduino.cc/en/Hacking/PinMapping168 for the 'raw' pin mapping
//UNO pin 2
//#define IRpin_PIN      PIND
//#define IRpin          2
//Mega pin 2
#define IRpin_PIN      PINE
#define IRpin          2
// the maximum pulse we'll listen for - 65 milliseconds is a long time
#define MAXPULSE 65000
// what our timing resolution should be, larger is better
// as its more 'precise' - but too large and you wont get
// accurate timing
#define RESOLUTION 20
// we will store up to 100 pulse pairs (this is -a lot-)
uint16_t pulses[100][2];  // pair is high and low pulse
uint8_t currentpulse = 0; // index for pulses we're storing
void setup(void) {
  Serial.println("Ready to decode IR!");
void loop(void) {
  uint16_t highpulse, lowpulse;  // temporary storage timing
  highpulse = lowpulse = 0; // start out with no pulse length
//  while (digitalRead(IRpin)) { // this is too slow!
    while (IRpin_PIN & (1 << IRpin)) {
     // pin is still HIGH
     // count off another few microseconds
     highpulse++;
     delayMicroseconds(RESOLUTION);
     // If the pulse is too long, we 'timed out' - either nothing
     // was received or the code is finished, so print what
     // we've grabbed so far, and then reset
     if ((highpulse >= MAXPULSE) && (currentpulse != 0)) {
       printpulses();
       currentpulse=0;
       return;
  // we didn't time out so lets stash the reading
  pulses[currentpulse][0] = highpulse;
  // same as above
  while (! (IRpin_PIN & _BV(IRpin))) {
     // pin is still LOW
     lowpulse++;
     if ((lowpulse >= MAXPULSE)  && (currentpulse != 0)) {
       printpulses();
       currentpulse=0;
       return;
  pulses[currentpulse][1] = lowpulse;
  // we read one high-low pulse successfully, continue!
  currentpulse++;
void printpulses(void) {
  Serial.println("\n\r\n\rReceived: \n\rOFF \tON");
  for (uint8_t i = 0; i < currentpulse; i++) {
    Serial.print(pulses[i][0] * RESOLUTION, DEC);
    Serial.print(" usec, ");
    Serial.print(pulses[i][1] * RESOLUTION, DEC);
    Serial.println(" usec");
  // print it in a 'array' format
  Serial.println("int IRsignal[] = {");
  Serial.println("// ON, OFF (in 10's of microseconds)");
  for (uint8_t i = 0; i < currentpulse-1; i++) {
    Serial.print("-");
    Serial.print(pulses[i][1] * RESOLUTION / 10, DEC);
    Serial.print(",");
    Serial.print(pulses[i+1][0] * RESOLUTION / 10, DEC);
    Serial.print(",");
  Serial.print(pulses[currentpulse-1][1] * RESOLUTION / 10, DEC);
  Serial.print(", 0};");
Gracias por vuestra ayuda, un saludo
No entiendo, cargas las librerías IRremote e Int pero no defines ningun objeto IRremote?
Luego haces todo como para reinventar la rueda!!
Te quiero decir que un simple ejemplo con IRremote leera cualquier RAW.
El mismo originador del hilo ha reportado esto:
Members who have reported this post
Reported by Carlitos1991 on Today at 05:53 pm. They left the following message:
Solucionado, no ha servido de mucho puesto que el compañero lleva razon. Por si se quiere borrar
Así que me limitaré a cerrar el hilo.
