PROGRAME ERROR
WHEN I COMPILE SAID CODE ON WEMOS D1 MINI MY BOARD GIVES BELOW ERROR
exit status 1
Error compiling for board WeMos D1 R2 & mini.
// Include Scheduler since we want to manage multiple tasks.
#include <Scheduler.h>
int led1 = D2;
int led2 = D3;
int led3 = D4;
// Setup the 3 pins as OUTPUT
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
// Add "loop2" and "loop3" to scheduling.
// "loop" is always started by default.
Scheduler.startLoop(loop2);
Scheduler.startLoop(loop3);
// Task no.1: blink LED with 1 second delay.
digitalWrite(led1, HIGH);
// IMPORTANT:
// When multiple tasks are running 'delay' passes control to
// other tasks while waiting and guarantees they get executed.
digitalWrite(led1, LOW);
// Task no.2: blink LED with 0.1 second delay.
void loop2() {
digitalWrite(led2, HIGH);
delay(2000);
digitalWrite(led2, LOW);
delay(2000);
// Task no.3: accept commands from Serial port
// '0' turns off LED
// '1' turns on LED
void loop3() {
if (Serial.available()) {
char c = Serial.read();
if (c=='0') {
digitalWrite(led3, LOW);
Serial.println("Led turned off!");
if (c=='1') {
digitalWrite(led3, HIGH);
Serial.println("Led turned on!");
// IMPORTANT:
// We must call 'yield' at a regular basis to pass
// control to other tasks.
yield();
There's probably more to the error than you have read and or posted.
Scroll or expand the pane to see more.
You should also have a "Copy error messages" button so you can more easily paste the whole thing.
