Programing an Uno to activate pint for relay if voltage is 11 volts
Hi, i am new to all of this. I have a 0 to 25v senor
How would i go about getting the uno to read voltage and activate a pin to activate a relay if voltage is over 11 volts? I can wire the relay to any pin and earth but reading other peoples codes cant understand enough to make alterations to work for me.
thanks
you connect the sensor to an analogue input (say A0) and read the value by calling analogRead(A0)
do you have a specification of the sensor?
also have a read of arduino realy tutorial
11V will be a reading of 450 from your analog input.
11 / (25/1024)
thanks
