Programing aurdino uno
"Hi,
Would need help with a code for Arduino Uno. It will be placed on a machine, so it needs to be reliable (I just can't get it right. I think it's easy for someone who knows.
My Arduino should control 4 relays with buttons.
When I press button 1, the following should happen:
Relay 1 (close grip) for 1.5 seconds, then relay 2 (extend) for 3 seconds, then relay 3 (open grip) for 1 second, then relay 4 (retract) for 3 seconds, then start over again.
IMPORTANT: When I release the button, everything should pause immediately and continue there i stoped then i press it again.
When I press button 2, the following should happen:
Relay 3 (open grip) for 1 second, then relay 4 (retract) for 3 seconds."
You're new here. Welcome!
Two paths.
  1. you want someone to code this for you. Fine, there's a subforum for that:
  1. You want help to get it done, but want to be involved in solving your problem. Okay, post the code you have so far, following the guidelines (above).
For those who are viewing this. This is just a simple correction to the parent post, It'll take the main post and rewrite it so others can understand...
Hello,
I would like help coding my Arduino Uno. It will be used on a machine, so it needs to be reliable.
The Arduino should control 4 relays with buttons, when I press button 1:
relay 1 will be powered for 1.5 seconds,
relay 2 will be powered for 3 seconds,
relay 3 will be powered for 1 second,
relay 4 will be powered for 3 seconds,
then it'll start over again.
IMPORTANT: When I release the button, everything should stop immediately and if I press it again it'll start back up where I stopped it at.
When I press button 2:
relay 3 will be powered for 1 second, then
relay 4 will be powered for 3 seconds.
- Spirit
@tinkercadtest has opened a duplicate topic in the Jobs and paid Consultancy category of the forum
See Aurdino uno r3 to 5v relay
