Hi serve professionals dear
i use a7 gsm/gps to make a gps tracker,
in default gps , agps and NEMA output are Close !!!
for active gps For every time you turn on the a7 module i need to :
1- "AT+GPS=1"
2- "AT+AGPS=1"
3- "AT+GPSRD=N" > NEMA information from AT N seconds once the output port, the actual use of the N into digital.
this is my code:
#include <SoftwareSerial.h>
SoftwareSerial gps(10, 11); // RX, TX
int gpsYear;
int gpsMonth;
int gpsDay = 0;
int gpsHour;
int gpsMin;
int gpsSec;
float gpsLat0;
float gpsLong0;
float gpsLat;
float gpsLong;
String gpsSpeed; //km/h
float gpsBearing; //deg
String latF;
String longF;
String Year;
String DateF;
String TimeF;
gps.begin(9600);
if (gps.available() > 1)
if (char(gps.read()) == 'R' && char(gps.read()) == 'M' && char(gps.read()) == 'C')
gpsTime(gps.parseInt());
gps.parseFloat(); //discard unnecessary part
gpsLatLong(gps.parseFloat(), gps.parseInt(), gps.parseFloat(), gps.parseInt());
gpsSpeed = String (gps.parseFloat()*1.852); //km/h
gpsBearing = gps.parseFloat();
gpsDate(gps.parseInt());
Serial.print(DateF);
Serial.print(" ");
Serial.print(TimeF);
Serial.print(" ");
Serial.print(latF);
Serial.print(" ");
Serial.print(longF);
Serial.print(" ");
Serial.println(gpsSpeed);
void gpsTime(long UTC)
gpsHour = int(UTC/10000);
gpsMin = int(UTC%10000/100);
gpsSec = int(UTC%100);
String gpsHour1 = String(gpsHour);
//String gpsMin1 = String(gpsMin);
//String gpsSec1 = String(gpsSec1);
TimeF=String(gpsHour1+":"+gpsMin+":"+gpsSec);
void gpsLatLong(float long2, int long1, float lat2, int lat1)
gpsLat = int(lat1/100) + float(((lat1%100)+lat2)/60);
latF=String(gpsLat,4);
//Serial.print(latF);
//Serial.print(" ");
gpsLong = int(long1/100) + float(((long1%100)+long2)/60);
longF=String(gpsLong,4);
//Serial.println(longF);
void gpsDate(long dateRead)
gpsDay = int(dateRead/10000);
gpsMonth = int(dateRead%10000/100);
gpsYear = dateRead%100; //last 2 digits, e.g. 2013-> 13
Year="20"+String(gpsYear);
DateF=String(Year + "-"+gpsMonth+"-"+gpsDay);
and this is my program output in serial monitor(GPSRD is set for 5 second) :
2017-7-19 14:19:49 32.4227 52.6457 0.00
2017-7-19 14:19:54 32.4227 52.6457 0.00
2017-7-19 14:20:9 32.4228 52.6457 0.00
2017-7-19 14:20:14 32.4228 52.6457 0.00
2017-7-19 14:20:19 32.4228 52.6457 0.00
2017-7-19 14:20:24 32.4227 52.6457 0.00
2017-7-19 14:20:29 32.4227 52.6457 0.00
but i have to active gps, agps and gpsrd in another program like this in serial monitor:
// initialize both serial ports:
Serial1.begin(9600);
// read from port 1, send to port 0:
if (Serial1.available()) {
int inByte = Serial1.read();
Serial.write(inByte);
// read from port 0, send to port 1:
if (Serial.available()) {
int inByte = Serial.read();
Serial1.write(inByte);
and then upload the original program
my idea is add this line in program :
int gpsYear;
int gpsMonth;
int gpsDay = 0;
int gpsHour;
int gpsMin;
int gpsSec;
float gpsLat0;
float gpsLong0;
float gpsLat;
float gpsLong;
String latF;
String longF;
String Year;
String DateF;
String TimeF;
gps.begin(9600);
delay(3000);
gps.println("AT+GPS=1");
delay(3000);
gps.println("AT+AGPS=1");
delay(25000);
gps.println("AT+GPSRD");
delay(5000);
Serial.print(" ");
Serial.print(" ");
Serial.print(latF);
Serial.print(" ");
Serial.print(" ");
but i dont see anything in serial monitor
