programm arduino
I HAVE PROGRAMMING A ARDUINO AND I HAVE A ERRROR LIKE THIS:
in function void value not ignored as it ought to be in function
MY PROGRAMM IS THIS:
void MoveMotorAZ(int iDeltaStepsAZ) {
int iCount;
Serial.print("Moving Azimuth motor this many steps: ");
Serial.println(iDeltaStepsAZ);
if (iDeltaStepsAZ == 0) {
return;
} // end if
if (iDeltaStepsAZ > 0) {
digitalWrite(MOTAZCWCCW,LOW); // positive CW = LOW
else {
iDeltaStepsAZ = -iDeltaStepsAZ;
digitalWrite(MOTAZCWCCW,HIGH); // negative CCW = HIGH
} // end if
delay(10);
if (iErrorAZFlag == 0) {
for (iCount=0; iCount=digitalWrite(MOTAZCLK, HIGH):wink: {// STEP 1.8 DEG (with 36 reduction = 0.05 deg)
delay(STEPDLY);
digitalWrite(MOTAZCLK, LOW);
delay(STEPDLY);
} // end for
} // end if
} // end MoveMotorAZ()
WHAT CAN I MAKE? CAN ANYWAY HELP ME PLEASE??
Please read this "How to use this forum": http://forum.arduino.cc/index.php?topic=149014.0
  1. use capital letters is like scream.
  2. code need to be enclose in special tags [ code] and /code else some pieces of code result unreadable like your for line (you see the little face? )
Take off caps lock or your thread will be deleted.
i'm srorry but i can very good english , i have a problem with my code for arduino , i use arduino 0018 my code is this :[void MoveMotorAZ(int iDeltaStepsAZ) { int iCount; Serial.print("Moving Azimuth motor this many steps: "); Serial.println(iDeltaStepsAZ); if (iDeltaStepsAZ == 0) { return; } // end if if (iDeltaStepsAZ > 0) { digitalWrite(MOTAZCWCCW,LOW); // positive CW = LOW } else { iDeltaStepsAZ = -iDeltaStepsAZ; digitalWrite(MOTAZCWCCW,HIGH); // negative CCW = HIGH } // end if delay(10); if (iErrorAZFlag == 0) { for (iCount=0; iCount=digitalWrite(MOTAZCLK, HIGH);) {// STEP 1.8 DEG (with 36 reduction = 0.05 deg) delay(STEPDLY); digitalWrite(MOTAZCLK, LOW); delay(STEPDLY); } // end for } // end if } // end MoveMotorAZ()] and i have a error of this: in function void value not ignored as it ought to be in function what can i make?
You can use google translator.
First, without TAGS the code present some missing parts. (modify message, select with mouse the code and use the button with #) section #7: http://forum.arduino.cc/index.php/topic,148850.0.html
Second in your function you use many variables not declared in function. They are declared where? We need all the code.
Have you tried searching for the error message “in function void value not ignored as it ought to be in function” ?
I get about 1.7 million matches from Google. I am sure that one or more of them will help.
[code]
#include <Wire.h>
#include <Servo.h>
//#include
//#include
#define ASCIIZERO 48 // '0' = 48
#define pi 3.1415926535897932384
#define twoPI (2.0*pi)
#define rad (pi/180.0)
#define dEarthRadius 6371.01 // in km
#define dAstroUnit 149597890 // in km
#define OPTOPINAZ 2
#define OPTOPINZE 3
#define MOTZECWCCW 5
#define MOTZECLK 4
#define MOTAZCWCCW 7
#define MOTAZCLK 6
#define MAXAZHOMESTEP 6250
#define MAXZEHOMESTEP 10000 // ZE home max subject to revision
#define STEPSAZHOME 1800 // AZ home position = East = +90 degrees = 1800 steps ***Update for final version => Home = 22.5 degrees***
#define ANGLEZEHOME 90.0 // ZE home position = Horizon = +90 degrees
#define STEPDLY 5
#define ZENITHHOMENUTPOSITION 24
#define STEPSPERDEGAZ 20.0 // 1.8 deg per step and 36:1 reduction worm gears
#define STEPSPERMMZE 100 // temporary demo
//Latitude and Longitude for McMaster (JHE) = 43.260181 (N), 79.920892 (W). Latitude is considered positive to the North and longitude to the East.
//Use decimal format (Latitude = 43 + 26.0181/60 = 43.434; Longitude = -1 * (79 degrees + 92.0892/60) = -80.535;)
const double MCMASTERLATITUDE = 43.434;
const double MCMASTERLONGITUDE = -80.535;
struct cTime {
int iYear;
int iMonth;
int iDay;
double dHours;
double dMinutes;
double dSeconds;
struct cLocation {
double dLongitude;
double dLatitude;
struct cSunCoordinates {
double dZenithAngle;
double dAzimuth;
struct cTime utcTime;
struct cLocation utcLocation;
struct cSunCoordinates utcSunCoordinates;
int iErrorAZFlag; // error flag homing AZ
int iErrorZEFlag; // error flag homing ZE
int iStepsAZ = STEPSAZHOME;
double dAngleZE = ANGLEZEHOME;
double dZenithNutPosition = ZENITHHOMENUTPOSITION;
int iCurrentZEsteps = 8692;
// setup serial communication
Wire.begin();
Serial.println("SolarTracker v4.4");
Serial.println("Serial Connection initalized");
Serial.println("");
pinMode(MOTAZCWCCW,OUTPUT); // AZ motor
pinMode(MOTAZCLK, OUTPUT);
pinMode(OPTOPINAZ, INPUT); // opto slot sensor AZ
digitalWrite(MOTAZCWCCW,HIGH); // always go home CCW = HIGH
pinMode(MOTZECWCCW,OUTPUT); // EL motor
pinMode(MOTZECLK, OUTPUT);
pinMode(OPTOPINZE, INPUT); // opto slot sensor ZE
digitalWrite(MOTZECWCCW,HIGH); // always go home CCW = HIGH
utcLocation.dLatitude = MCMASTERLATITUDE;
utcLocation.dLongitude = MCMASTERLONGITUDE;
Serial.println("Location: McMaster University, Hamilton, ON");
Serial.print("Latitude (Decimal Format): "); Serial.println(utcLocation.dLatitude);
Serial.print("Longitude (Decimal Format): "); Serial.println(utcLocation.dLongitude);
Serial.println("");
// home the AZ stepper by looking for blocked opto slot, when home = East = 90 degrees = 1800 steps
homeAzimuth();
// home the Zenith stepper
homeZenith();
} // end setup()
  getCurrentTime();
beginTracking();
Serial.println("");
delay(2000);
} // end loop()
void homeAzimuth() {
Serial.println("");
Serial.println("Homing the Azimuth-tracking stage to 90 degrees East of North");
// Home the AZ stepper by looking for blocked opto slot. Home = East = 90 degrees = 1800 steps
iErrorAZFlag = 0;
int iCount;
int optoStateAZ;
for (iCount=0; iCount;) {// should be home in 180 deg worth of steps
     optoStateAZ = digitalRead(OPTOPINAZ);
if (optoStateAZ == HIGH)
{           // HIGH is blocked (home)
   break; // now home
} // end if
digitalWrite(MOTAZCLK, HIGH); // STEP 1.8 DEG (with 36 reduction = 0.05 deg)
delay(STEPDLY);
delay(STEPDLY);
} // end for
  if (iCount < MAXAZHOMESTEP){
// safely home
       iErrorAZFlag = 0;
// didn't get home in 270 deg
      iErrorAZFlag = 1;
    } // end if
 }// end homeAzimuth()
void homeZenith() {
Serial.println("Homing the Zenith-tracking stage to +90 degrees (Horizon)");
Serial.println("");
iErrorZEFlag = 0;
int iCount;
int optoStateZE;
for (iCount=0; iCount;){// should be home in 180 deg worth of steps
optoStateZE = digitalRead(OPTOPINZE);
if (optoStateZE == HIGH) { // HIGH is blocked (home)
break; // now home
} // end if
digitalWrite(MOTZECLK, HIGH); // STEP 1.8 DEG (document amount ratio)
delay(STEPDLY);
digitalWrite(MOTZECLK, LOW);
delay(STEPDLY);
} // end for
if (iCount < MAXZEHOMESTEP) {
// safely home
iErrorZEFlag = 0;
else {
// didn't get home
iErrorZEFlag = 1;
} // end if
} // end homeZenith()
void beginTracking() {
Serial.println("Solar Tracking Initalized.");
Serial.println("-----------------------------------------------------");
int iDeltaStepsAZ,iDeltaStepsZE;
GetSunPos(utcTime,utcLocation,&utcSunCoordinates); // get the current solar vector
Serial.print("Azimuth = "); Serial.println(utcSunCoordinates.dAzimuth);
Serial.print("Zenith = "); Serial.println(utcSunCoordinates.dZenithAngle);
Serial.print("Motor AZ= "); Serial.print((double)iStepsAZ/(double)STEPSPERDEGAZ);
Serial.print(" Current iStepsAZ= "); Serial.print(iStepsAZ);
iDeltaStepsAZ = (int)(utcSunCoordinates.dAzimuth*STEPSPERDEGAZ) - iStepsAZ;
Serial.print(" iDeltaStepsAZ= "); Serial.println(iDeltaStepsAZ);
MoveMotorAZ(iDeltaStepsAZ);
iStepsAZ = (int)(utcSunCoordinates.dAzimuth*STEPSPERDEGAZ);
Serial.print("Motor ZE= "); Serial.print(dAngleZE);
Serial.print(" Current dAngleZE= "); Serial.println(dAngleZE);
Serial.print("utcSunCoordinates.dZenithAngle = ");
Serial.println(utcSunCoordinates.dZenithAngle, DEC);
if (utcSunCoordinates.dZenithAngle > 00.1 && utcSunCoordinates.dZenithAngle < 89.9) {
int iFutureZEsteps = getZenithSteps(utcSunCoordinates.dZenithAngle);
int deltaZenithSteps = iCurrentZEsteps - iFutureZEsteps; //store in getZenith result in variable
MoveMotorZE(deltaZenithSteps);
dAngleZE = utcSunCoordinates.dZenithAngle;
iCurrentZEsteps = iFutureZEsteps;
else {
Serial.println(" The sun has set - no update");
homeAzimuth();
homeZenith();
} // end if
} // end beginTracking()
int iCount;
return;
} // end if
else {
} // end if
delay(10);
  delay(STEPDLY);
  delay(STEPDLY);
} // end for
} // end if
void MoveMotorZE(int iDeltaStepsZE) {
int iCount;
Serial.print("Moving Zenith motor this many steps: ");
Serial.println(iDeltaStepsZE);
if (iDeltaStepsZE == 0) {
return;
} // end if
if (iDeltaStepsZE > 0) {
digitalWrite(MOTZECWCCW,HIGH); // positive CW = LOW
else {
iDeltaStepsZE = -iDeltaStepsZE;
digitalWrite(MOTZECWCCW,LOW); // negative CCW = HIGH
} // end if
delay(10);
if (iErrorZEFlag == 0) {
for (iCount=0; iCountdigitalWrite(MOTZECLK, HIGH); // STEP 1.8 DEG (with 36 reduction = 0.05 deg)
delay(STEPDLY);
delay(STEPDLY);
} // end for
} // end if
} // end MoveMotorZE()
[/code]
yes i have it tries but i dont understand the more. i try to make a traker for fotovoltaic my code is longer that i have send to you , i cant send all the code because they send it is to long.
#include <Wire.h>
#include <Servo.h>
//#include
//#include
#define OPTOPINAZ 2
#define OPTOPINZE 3
#define MOTZECLK 4
#define MOTAZCLK 6
#define STEPDLY 5
struct cTime {
int iYear;
int iMonth;
int iDay;
double dHours;
double dMinutes;
double dSeconds;
struct cLocation {
double dLongitude;
double dLatitude;
double dAzimuth;
Wire.begin();
Serial.println("");
Serial.println("");
homeAzimuth();
homeZenith();
} // end setup()
  getCurrentTime();
beginTracking();
Serial.println("");
delay(2000);
} // end loop()
void getCurrentTime() {
Wire.beginTransmission(0x68);
Wire.send(0); // point to address of the timekeeping registers
Wire.endTransmission();
Wire.requestFrom(0x68, 7); // request 7 bytes from DS1307
utcTime.dSeconds = convertHEX(Wire.receive());
utcTime.dMinutes = convertHEX(Wire.receive());
utcTime.dHours = convertHEX(Wire.receive());
Wire.receive(); // disregard the day of the week
utcTime.iDay = convertHEX(Wire.receive());
utcTime.iMonth = convertHEX(Wire.receive());
utcTime.iYear = 2000 + convertHEX(Wire.receive());
Serial.println("");
Serial.println("Universal Coordinate Time");
Serial.print("Time (Hh:Mm:Ss): ");
if ((int)utcTime.dHours < 10) Serial.print("0");
Serial.print((int)utcTime.dHours, DEC);
Serial.print(":");
if ((int)utcTime.dMinutes < 10) Serial.print("0");
Serial.print((int)utcTime.dMinutes, DEC);
Serial.print(":");
if (utcTime.dSeconds < 10) Serial.print("0");
Serial.println((int)utcTime.dSeconds, DEC);
Serial.print("Date (Dd/Mm/YYYY) ");
if (utcTime.iDay < 10) Serial.print("0");
Serial.print(utcTime.iDay, DEC);
Serial.print("/");
if (utcTime.iMonth < 10) Serial.print("0");
Serial.print(utcTime.iMonth, DEC);
Serial.print("/");
if (utcTime.iYear < 10) Serial.print("0");
Serial.println(utcTime.iYear, DEC);
Serial.println("");
} // end getCurrentTime()
Serial.println("");
iErrorAZFlag = 0;
int iCount;
int optoStateAZ;
   break; // now home
} // end if
delay(STEPDLY);
delay(STEPDLY);
} // end for
// safely home
       iErrorAZFlag = 0;
      iErrorAZFlag = 1;
    } // end if
void homeZenith() {
Serial.println("");
iErrorZEFlag = 0;
int iCount;
int optoStateZE;
break; // now home
} // end if
delay(STEPDLY);
delay(STEPDLY);
} // end for
// safely home
iErrorZEFlag = 0;
else {
// didn't get home
iErrorZEFlag = 1;
} // end if
else {
homeAzimuth();
homeZenith();
} // end if
int iCount;
return;
} // end if
else {
} // end if
delay(10);
  delay(STEPDLY);
  delay(STEPDLY);
} // end for
} // end if
int iCount;
return;
} // end if
else {
} // end if
delay(10);
delay(STEPDLY);
delay(STEPDLY);
} // end for
} // end if
void GetSunPos(struct cTime utcTime, struct cLocation utcLocation, struct cSunCoordinates *utcSunCoordinates)
// Main variables
double dElapsedJulianDays;
double dDecimalHours;
double dEclipticLongitude;
double dEclipticObliquity;
double dRightAscension;
double dDeclination;
// Auxiliary variables
double dY;
double dX;
// Calculate difference in days between the current Julian Day
// and JD 2451545.0, which is noon 1 January 2000 Universal Time
double dJulianDate;
long int liAux1;
long int liAux2;
// Calculate time of the day in UT decimal hours
dDecimalHours = utcTime.dHours + (utcTime.dMinutes
+ utcTime.dSeconds / 60.0 ) / 60.0;
// Calculate current Julian Day
liAux1 =(utcTime.iMonth-14)/12;
liAux2=(1461*(utcTime.iYear + 4800 + liAux1))/4 + (367*(utcTime.iMonth
- 2-12*liAux1))/12- (3*((utcTime.iYear + 4900
+ liAux1)/100))/4+utcTime.iDay-32075;
dJulianDate=(double)(liAux2)-0.5+dDecimalHours/24.0;
// Calculate difference between current Julian Day and JD 2451545.0
dElapsedJulianDays = dJulianDate-2451545.0;
// Calculate ecliptic coordinates (ecliptic longitude and obliquity of the
// ecliptic in radians but without limiting the angle to be less than 2*Pi
// (i.e., the result may be greater than 2*Pi)
   double dMeanLongitude;
   double dMeanAnomaly;
   double dOmega;
   dOmega=2.1429-0.0010394594*dElapsedJulianDays;
   dMeanLongitude = 4.8950630+ 0.017202791698*dElapsedJulianDays; // Radians
   dMeanAnomaly = 6.2400600+ 0.0172019699*dElapsedJulianDays;
   dEclipticLongitude = dMeanLongitude + 0.03341607*sin( dMeanAnomaly )
           + 0.00034894*sin( 2*dMeanAnomaly )-0.0001134
            -0.0000203*sin(dOmega);
  dEclipticObliquity = 0.4090928 - 6.2140e-9*dElapsedJulianDays
  +             0.0000396*cos(dOmega);
// Calculate celestial coordinates ( right ascension and declination ) in radians
// but without limiting the angle to be less than 2*Pi (i.e., the result may be
// greater than 2*Pi)
    double dSin_EclipticLongitude;
    dSin_EclipticLongitude= sin( dEclipticLongitude );
    dY = cos( dEclipticObliquity ) * dSin_EclipticLongitude;
    dX = cos( dEclipticLongitude );
    dRightAscension = atan2( dY,dX );
    if( dRightAscension < 0.0 ) dRightAscension = dRightAscension + twoPI;
    dDeclination = asin( sin( dEclipticObliquity )*dSin_EclipticLongitude );
// Calculate local coordinates ( azimuth and zenith angle ) in degrees
    double dGreenwichMeanSiderealTime;
    double dLocalMeanSiderealTime;
    double dLatitudeInRadians;
    double dHourAngle;
    double dCos_Latitude;
    double dSin_Latitude;
    double dCos_HourAngle;
    double dParallax;
    dGreenwichMeanSiderealTime = 6.6974243242 +0.0657098283*dElapsedJulianDays + dDecimalHours;
    dLocalMeanSiderealTime = (dGreenwichMeanSiderealTime*15+ utcLocation.dLongitude)*rad;
    dHourAngle = dLocalMeanSiderealTime - dRightAscension;
    dLatitudeInRadians = utcLocation.dLatitude*rad;
    dCos_Latitude = cos( dLatitudeInRadians );
    dSin_Latitude = sin( dLatitudeInRadians );
    dCos_HourAngle= cos( dHourAngle );
    utcSunCoordinates->dZenithAngle = (acos( dCos_Latitude*dCos_HourAngle *cos(dDeclination) + sin( dDeclination )*dSin_Latitude));
    dY = -sin( dHourAngle );
    dX = tan( dDeclination )*dCos_Latitude - dSin_Latitude*dCos_HourAngle;
    utcSunCoordinates->dAzimuth = atan2( dY, dX );
    if ( utcSunCoordinates->dAzimuth < 0.0 )
    utcSunCoordinates->dAzimuth = utcSunCoordinates->dAzimuth + twoPI;
    utcSunCoordinates->dAzimuth = utcSunCoordinates->dAzimuth/rad;
     // Parallax Correction
    dParallax=(dEarthRadius/dAstroUnit)*sin(utcSunCoordinates->dZenithAngle);
    utcSunCoordinates->dZenithAngle= (utcSunCoordinates->dZenithAngle+ dParallax)/rad;
} // end GetSunPos()
byte convertHEX(byte value) {
//This works for decimal 0-99
  return ((value/16*10) + (value%16));
} // end convertHEX
int getZenithSteps(double theta) {
  double beta0; // Initial guess
  double beta; // Approximate solution
  double epsilon; // Maximum error
  int maxIterations; // Maximum number of iterations
  int iterations; // Actual number of iterations
  int converged; // Whether iteration converged
  double thetaRAD = theta * rad;
  beta0 = 0;
  epsilon = 0.00001;
  maxIterations = 10000;
  double nutPosition =-1;
  // Find the first positive solution.
   while (nutPosition <= 0) {
     beta = newtonsMethod(beta0, epsilon, maxIterations, &iterations, &converged, thetaRAD);
     nutPosition = 25*cos(thetaRAD) + 53*cos(thetaRAD+PI+beta);
     beta0++;
if (converged) {
  Serial.print("Newton algorithm converged after this many steps: ");
  Serial.println(iterations, DEC);
  Serial.print("f(");
  Serial.print(beta, DEC);
  Serial.print(") = ");
  Serial.println(f(thetaRAD, beta), DEC);
else {
  Serial.println("Newton's method algorithm didn't converge");
  Serial.print("The final estimate was: ");
// Serial.println("");
// Serial.print("|AD| length (mm): ");
// Serial.println(nutPosition, DEC);
//calculate and return number of steps
// 0.004mm per step
  return ((int)(nutPosition / 0.004));
} // end getZenithSteps
double newtonsMethod(double beta0, double epsilon, int maxIterations,
      int* iterations_p, int* converged_p, double thetaRAD ) {
  double beta = beta0;
  double beta_prev;
  int iter = 0;
do {
    iter++;
    beta_prev = beta;
    beta = beta_prev - f(thetaRAD, beta_prev)/f_prime(thetaRAD, beta_prev);
} while (fabs(beta - beta_prev) > epsilon && iter < maxIterations);
 if (fabs(beta - beta_prev) <= epsilon)
     *converged_p = 1;
     *converged_p = 0;
     *iterations_p = iter;
 return beta;
} // end newtonsMethod
double f(double thetaRAD, double beta) {
    return 15 + 25*sin(thetaRAD) - 53*sin(thetaRAD + beta);
} // end f
double f_prime(double thetaRAD, double beta) {
    return -53*cos(thetaRAD + beta); //the derivative
} // end f_prime
Please stop. You can attach your file to a post. There is no character limit on this method.
It's a good job you got this error before your sketch got too large.
i have send all the code , i use arduino 0018 , please can anybudy help me?
i use arduino 0018
Why?
digitalWrite doesn't return a value, therefore you got an error.
i dont have a reason , becasuse i have with this begin
I don't understand your reply.
You didn't write that code. Do you have a link to where you got it from?
i have it from there:http://mech.mcmaster.ca/~adspence/Teaching/Outlines/MechEng4B03/SolarTrackerReportExample.pdf
nopi: i dont have a reason , becasuse i have with this begin
You can download the IDE 1.0.5 (the last) or at least the 0023 version.
