#include <Servo.h>
const int echo1 = 5; // Ultrasonic 1 Signal Empfänger Pin
const int trig1 = 4; // Ultrasonic 1 Signal Sender Pin
int a[4]={0, 1, 2, 3};
int Ruecklicht[48]={48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95};
int Frontlicht[48]={0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47};
int rfid = 0; // RFID variable
int value1 = 0; // variable RFID
const int relaisPin1 = 33; // Relay Motor ON
const int relaisPin2 = 36; // Relais Motor halt
int duration1 = 0; // Dauer für Schallweg Sensor 1
int distance1 = 0; // Distanz für Schallweg Sensor 1
#ifdef AVR
#include <avr/power.h>
#endif
#define LED_PIN 10
#define LED_COUNT 95
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRBW + NEO_KHZ800);
#define DELAYVAL 500 // Time (in milliseconds) to pause between pixels
#define BRIGHTNESS 255 // Helligkeit der LED`s
Servo servo;
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 53 // RFID PIN
#define RST_PIN 49 // RFID PIN
MFRC522 mfrc522(SS_PIN, RST_PIN);
pinMode(trig1, OUTPUT); // Ultrasonic 1 Signal Sender Pin
pinMode(echo1, INPUT); // Ultrasonic 1 Signal Empfänger Pin
pinMode(31, INPUT_PULLUP); // Raspberry Input Signal ON
pinMode(relaisPin1, OUTPUT); // Relais Motor
pinMode(relaisPin2, OUTPUT); // Relais Motor Halt
servo.attach(6); // Servomotor Pinbestimmung
Serial.begin(115200); // Baudrate
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
clock_prescale_set(clock_div_1);
#endif
strip.begin();
strip.show();
strip.setBrightness(BRIGHTNESS);
digitalWrite (relaisPin1, LOW); // Aktivierung Relais
digitalWrite (relaisPin2, LOW); // Aktivierung Relais
SPI.begin();
mfrc522.PCD_Init();
int a = digitalRead (31);
Serial.println (a);
RFID ();
if (rfid >= 1)
LED();
if (a == HIGH)
digitalWrite(relaisPin1, LOW);
digitalWrite(relaisPin2, LOW);
if (a == LOW)
Bremslicht();
ultrasonic(); // Start void Ultrasonic wenn Raspberrykamera erkennt
void ultrasonic () // Ultraschallsensoren starten
digitalWrite(trig1, HIGH); // Sender 1 ON
delay (15);
digitalWrite(trig1, LOW); // Sender 1 OFF
duration1 = pulseIn(echo1, HIGH); // Empfänger 1 ON
distance1 = (duration1/2) / 28.5; // Dauer Schallweg : 2 mit Temperaturkoeffizient
Serial.println(distance1); // Ergebnis der Berechnung Distanz Sensor 1
if (distance1 > 150)
digitalWrite(relaisPin1, LOW); // Wenn Distanz über 80 dann schaltet Relais 1 und 2 Motor aus
digitalWrite(relaisPin2, LOW); // Wenn Distanz unter 80 schaltet Motor Halt ein
if (distance1 >= 120 && distance1 <=150) // Distanz der Messungen definiert zwischen 60cm und 100cm
digitalWrite(relaisPin1, HIGH); // Wenn Distanz Richtig dann schaltet Relais 1 und 2 Motor Start
digitalWrite(relaisPin2, LOW); // Wenn Distanz über 60 schaltet Motor Halt Aus
if ( distance1 < 80 ) // Distanz Messung definiert kleiner 40cm
digitalWrite(relaisPin2, HIGH); // Wenn Distanz unter 80 schaltet Motor Halt ein
int Winkel = map (distance1, 25, 80 ,90, 0); // Servowinkel definiert wenn 25 cm dann Servo 90 Grad und wenn 80 cm 0 Grad (zwischenstufen werden acuh geregelt)
servo.write(Winkel); // Ergebnis Winkel für Servo
if (distance1 < 120)
if (distance1 >=80)
void RFID()
if( ! mfrc522.PICC_IsNewCardPresent())
return;
if( ! mfrc522.PICC_ReadCardSerial())
return;
long code=0; // Als neue Variable fügen wir „code“ hinzu, unter welcher später die UID als zusammenhängende Zahl ausgegeben wird. Statt int benutzen wir jetzt den Zahlenbereich „long“, weil sich dann eine größere Zahl speichern lässt.
for (byte i = 0; i < mfrc522.uid.size; i++)
code=((code+mfrc522.uid.uidByte[i])*10); // Nun werden wie auch vorher die vier Blöcke ausgelesen und in jedem Durchlauf wird der Code mit dem Faktor 10 „gestreckt“. (Eigentlich müsste man hier den Wert 1000 verwenden, jedoch würde die Zahl dann zu groß werden.
Serial.print("Die Kartennummer lautet:"); // Zum Schluss wird der Zahlencode (Man kann ihn nicht mehr als UID bezeichnen) ausgegeben.
Serial.println(code);
switch(code)
case 1226020:
rfid = rfid +1;
value1 = 0;
case 2582490:
rfid = rfid +1;
value1 = 0;
case 2507190:
rfid = rfid +1;
value1 = 0;
case 1225010:
rfid = rfid +1;
value1 = 0;
case 1226720:
rfid = rfid +1;
value1 = 0;
case 2564010:
rfid = rfid +1;
value1 = 0;
case 900420:
rfid = rfid +1;
value1 = 0;
case 1975030:
rfid = rfid +1;
value1 = 0;
case 1935690:
rfid = rfid +1;
value1 = 0;
void LED()
if (rfid == 1)
strip.setPixelColor(Ruecklicht, strip.Color(20, 0, 0, 0)); // Helligkeit und Farbe Ruecklicht
strip.setPixelColor(Frontlicht, strip.Color(255, 255, 255, 255)); // Helligkeit und Farbe Frontlicht
strip.show(); // Bringt Pixel zum leuchten
delay (1000);
rfid = rfid + 1;
void Bremslicht()
if (distance1 < 80)
strip.setPixelColor(Ruecklicht, strip.Color(100, 0, 0, 0)); // Helligkeit und Farbe Bremslicht
if (distance1 > 80)
strip.setPixelColor(Ruecklicht, strip.Color(20, 0, 0, 0)); // Wechsel auf Helligkeit von Bremslicht auf Rücklicht
