Programmable LED
Hi!
I found a tutorial from Instructables.com that teaches how to make a programmable blinking led by using ATtiny13v + led + LDR (Light Dependent Resistor).
http://www.instructables.com/id/Programmable-LED/
You wave some thing in front of LDR and ATtiny saves the pattern and starts to blink like that.
So now im looking for a way to implement that code to Arduino (ATMega 328).
Can anyone help me?
here is the code from Instructables:
 * Title:    flick led
 * Author:   Alexander Weber <alexander.weber.0 at gmail.com>
 * Date:     21.02.2007
 * Hardware: ATtiny13v
 * Software: WinAVR 20060421
// define as -D switch
//#define F_CPU 1200000	// Taktfrequenz: 1.2MHz, internal oscillator
#include <avr/io.h>
#include <util/delay.h>
#define TRUE 1
#define FALSE 0
#define ON 1
#define OFF 0
// use PB2 for led, pin 7
#define LED_BIT 2
// use PB3 to enable ldr, pin 2
#define ADC_ENA_BIT 3
// pause
#define PAUSE 25
// select ADC2, PB4, pin 3
#define CHANNEL 2
// values over threshold are recorded as "on"
#define THRESHOLD 800
// storage for recorded values
#define MAX 400
static uint8_t values[MAX / 8];
 * get_adc
 * Return the 10bit value of the selected adc channel.
uint16_t get_adc(uint8_t channel) {
	// enable voltage for adc
	PORTB |= (1 << ADC_ENA_BIT);
	// ADC setup
	ADCSRA =
		(1 << ADEN) |					// enable ADC
		(1 << ADPS1) | (1 << ADPS0);	// set prescaler to 8
	// select channel
	ADMUX = channel;
	// select reference voltage
	// ADMUX |= (1 << REFS0);	// use internal reference
	// warm up the ADC, discard the first conversion
	ADCSRA |= (1 << ADSC);
	while (ADCSRA & (1 << ADSC));
	ADCSRA |= (1 << ADSC);				// start single conversion
	while (ADCSRA & (1 << ADSC)); 		// wait until conversion is done
	PORTB &= ~(1 << ADC_ENA_BIT);		// disable voltage for adc
	return ADCW;
int main(void) {
	uint16_t i = 0;
	uint16_t count = 0;
	uint8_t light = OFF;
	uint8_t last_light = OFF;
	uint16_t last_time = 0;
	uint8_t programming = TRUE;
	// define LED and ADC enable as outputs
	DDRB |= (1 << LED_BIT) |
			(1 <<ADC_ENA_BIT);
	// intro
	for (i = 0; i < 5; i++) {
		PORTB |= (1 << LED_BIT);
		_delay_ms(200);
		PORTB &= ~(1 << LED_BIT);
		_delay_ms(200);
		_delay_ms(100);
	while (1) {
		if (programming) {
			// signal that we are ready to program
				_delay_ms(40);
				_delay_ms(40);
			// now read the ldr and store it
			for (i = 0; i < MAX; i++) {
				if (get_adc(CHANNEL) > THRESHOLD) {
					values[i / 8] |= (1 << (i % 8));
				else {
					values[i / 8] &= ~(1 << (i % 8));
				_delay_ms(PAUSE);
			// signal that we are finished with programming
				_delay_ms(40);
				_delay_ms(40);
			// switch to playback
			programming = FALSE;
			count = 0;
		else {
			// have we detected a change?
			light = (get_adc(CHANNEL) > THRESHOLD) ? ON : OFF;
			if (light != last_light) {
				// when was the last change?
				if ((count - last_time) == 10) {
					programming = TRUE;			// switch to programming mode
				else {
					last_time = count;
			last_light = light;
			// replay recorded lights
			if (values[count / 8] & (1 << (count % 8))) {
			else {
			_delay_ms(PAUSE);
			count++;
			if (count == MAX) {
				count = 0;
	return 0;
Also this code compiles under Arduino IDE but i dont know how to connect the led and LDR using that code.
.. or is there any code that can demonstrate the Arduino is able to learn something and then playing it back
that code should almost complete convert directly into arduino IDE, but you're asking how to hook it up? did you not post a photo showing how it was hooked up?
