Programmation for pulse sensor and adafruit bluefruit le uart friend
I'm doing a heart rate mointor using a pulse sensor and a adafruit bluefruit le uart friend. I'm kind of confused on some things, since is my first time using Arduino. I'm using the example heart rate monitor from the library adafruit bluefruit nRf5. What I'm not sure is if I need to include the information of the wire connections that I'm gonna be using for the pulse sensor or use the code as it is. I'm new at this and there are so many terms I don't understand from this code. This is the code:
This is an example for our nRF51822 based Bluefruit LE modules
Pick one up today in the adafruit shop!
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
MIT license, check LICENSE for more information
All text above, and the splash screen below must be included in
any redistribution
Please note the long strings of data sent mean the RTS pin is
required with UART to slow down data sent to the Bluefruit LE!
#include <Arduino.h>
#include <SPI.h>
#include "Adafruit_BLE.h"
#include "Adafruit_BluefruitLE_SPI.h"
#include "Adafruit_BluefruitLE_UART.h"
#include "BluefruitConfig.h"
#if SOFTWARE_SERIAL_AVAILABLE
#include <SoftwareSerial.h>
#endif
// Create the bluefruit object, either software serial...uncomment these lines
SoftwareSerial bluefruitSS = SoftwareSerial(BLUEFRUIT_SWUART_TXD_PIN, BLUEFRUIT_SWUART_RXD_PIN);
Adafruit_BluefruitLE_UART ble(bluefruitSS, BLUEFRUIT_UART_MODE_PIN,
BLUEFRUIT_UART_CTS_PIN, BLUEFRUIT_UART_RTS_PIN);
/* ...or hardware serial, which does not need the RTS/CTS pins. Uncomment this line */
// Adafruit_BluefruitLE_UART ble(BLUEFRUIT_HWSERIAL_NAME, BLUEFRUIT_UART_MODE_PIN);
/* ...hardware SPI, using SCK/MOSI/MISO hardware SPI pins and then user selected CS/IRQ/RST */
Adafruit_BluefruitLE_SPI ble(BLUEFRUIT_SPI_CS, BLUEFRUIT_SPI_IRQ, BLUEFRUIT_SPI_RST);
/* ...software SPI, using SCK/MOSI/MISO user-defined SPI pins and then user selected CS/IRQ/RST */
//Adafruit_BluefruitLE_SPI ble(BLUEFRUIT_SPI_SCK, BLUEFRUIT_SPI_MISO,
// BLUEFRUIT_SPI_MOSI, BLUEFRUIT_SPI_CS,
// BLUEFRUIT_SPI_IRQ, BLUEFRUIT_SPI_RST);
// A small helper
void error(const __FlashStringHelper*err) {
Serial.println(err);
while (1);
/* The service information */
int32_t hrmServiceId;
int32_t hrmMeasureCharId;
int32_t hrmLocationCharId;
@brief Sets up the HW an the BLE module (this function is called
automatically on startup)
void setup(void)
while (!Serial); // required for Flora & Micro
boolean success;
Serial.println(F("Adafruit Bluefruit Heart Rate Monitor (HRM) Example"));
Serial.println(F("---------------------------------------------------"));
randomSeed(micros());
/* Initialise the module */
Serial.print(F("Initialising the Bluefruit LE module: "));
if ( !ble.begin(VERBOSE_MODE) )
error(F("Couldn't find Bluefruit, make sure it's in CoMmanD mode & check wiring?"));
Serial.println( F("OK!") );
/* Perform a factory reset to make sure everything is in a known state */
Serial.println(F("Performing a factory reset: "));
if (! ble.factoryReset() ){
error(F("Couldn't factory reset"));
/* Disable command echo from Bluefruit */
ble.echo(false);
Serial.println("Requesting Bluefruit info:");
/* Print Bluefruit information */
ble.info();
// this line is particularly required for Flora, but is a good idea
// anyways for the super long lines ahead!
// ble.setInterCharWriteDelay(5); // 5 ms
/* Change the device name to make it easier to find */
Serial.println(F("Setting device name to 'Bluefruit HRM': "));
if (! ble.sendCommandCheckOK(F("AT+GAPDEVNAME=Bluefruit HRM")) ) {
error(F("Could not set device name?"));
/* Add the Heart Rate Service definition /
Service ID should be 1 */
Serial.println(F("Adding the Heart Rate Service definition (UUID = 0x180D): "));
success = ble.sendCommandWithIntReply( F("AT+GATTADDSERVICE=UUID=0x180D"), &hrmServiceId);
if (! success) {
error(F("Could not add HRM service"));
/* Add the Heart Rate Measurement characteristic /
Chars ID for Measurement should be 1 */
Serial.println(F("Adding the Heart Rate Measurement characteristic (UUID = 0x2A37): "));
success = ble.sendCommandWithIntReply( F("AT+GATTADDCHAR=UUID=0x2A37, PROPERTIES=0x10, MIN_LEN=2, MAX_LEN=3, VALUE=00-40"), &hrmMeasureCharId);
if (! success) {
error(F("Could not add HRM characteristic"));
/* Add the Body Sensor Location characteristic /
Chars ID for Body should be 2 */
Serial.println(F("Adding the Body Sensor Location characteristic (UUID = 0x2A38): "));
success = ble.sendCommandWithIntReply( F("AT+GATTADDCHAR=UUID=0x2A38, PROPERTIES=0x02, MIN_LEN=1, VALUE=3"), &hrmLocationCharId);
if (! success) {
error(F("Could not add BSL characteristic"));
/* Add the Heart Rate Service to the advertising data (needed for Nordic apps to detect the service) */
Serial.print(F("Adding Heart Rate Service UUID to the advertising payload: "));
ble.sendCommandCheckOK( F("AT+GAPSETADVDATA=02-01-06-05-02-0d-18-0a-18") );
/* Reset the device for the new service setting changes to take effect */
Serial.print(F("Performing a SW reset (service changes require a reset): "));
ble.reset();
/** Send randomized heart rate data continuously **/
void loop(void)
int heart_rate = random(50, 100);
Serial.print(F("Updating HRM value to "));
Serial.print(heart_rate);
Serial.println(F(" BPM"));
/* Command is sent when \n (\r) or println is called /
AT+GATTCHAR=CharacteristicID,value */
ble.print( F("AT+GATTCHAR=") );
ble.print( hrmMeasureCharId );
ble.print( F(",00-") );
ble.println(heart_rate, HEX);
/* Check if command executed OK */
if ( !ble.waitForOK() )
Serial.println(F("Failed to get response!"));
/* Delay before next measurement update */
I will really appreciate your help. Thanks.
adafruit uses to have tutorials.
Here about the heartrate sensor
here about the [adafruit bluefruit le uart friend
It is very clear to me that having read these two tutorials is not sufficient to understand it all.
It is very likely that there are still questions unanswered.
If you refer to a tutorial linking to the tutorial quoting the tutorial and ask specific questions about a detail. It will become much easier to answer for others.
It will be useful for you to learn some basics about programming in general because these basics apply to your project
Take a look into this tutorial:
Arduino Programming Course
It is easy to understand and has a good mixture between explaining important concepts and example-codes to get you going. So give it a try and report your opinion about this tutorial.
OK I think I figure it out how to post the entire code following your instructions.
[code]
 any redistribution
    Please note the long strings of data sent mean the *RTS* pin is
#include <SPI.h>
#define BLUEFRUIT_SWUART_RXD_PIN       9    // Required for software serial!
#define BLUEFRUIT_SWUART_TXD_PIN       10   // Required for software serial!
#define BLUEFRUIT_UART_CTS_PIN         11   // Required for software serial!
#define BLUEFRUIT_UART_RTS_PIN         8    // Optional, set to -1 if unused
#endif
// A small helper
  while (1);
void setup(void)
  boolean success;
  ble.echo(false);
  ble.info();
  /* Add the Heart Rate Service definition */
  /* Service ID should be 1 */
  if (! success) {
  /* Add the Heart Rate Measurement characteristic */
  /* Chars ID for Measurement should be 1 */
    if (! success) {
  /* Add the Body Sensor Location characteristic */
  /* Chars ID for Body should be 2 */
    if (! success) {
  ble.reset();
void loop(void)
  /* Command is sent when \n (\r) or println is called */
  /* AT+GATTCHAR=CharacteristicID,value */
[/code]
I tried this sketch and it didn't work. I'm trying to display the information gathered from a pulse sensor in the nRF toolbox app to see the heart rate, but no information is shown. I'm not sure what mistake I'm making so I will really appreciate some help.
[quote="mace2118, post:4, topic:1052979"]
Hi Mace,
well done posting the code as a code-section.
Not all users have your hardware
and if they have your hardware it might be that the hardware is wired differently
please take a look "from above" onto the communication in this thread:
You wrote a first question you received an answer how to improve communication.
You followed this improvement partially. (Posting your sketch as a code-section)
You got additional information (the links to the tutorials)
Then you posted three lines saying
  1. sketch does not work
  2. repeated what your aim is
  3. some rather vague info about your knowledge-level
My answer is asking back for the details.
My reply is written 5h later.
Which means proceeding in your project is delayed 5 hours plus the hours until you look into the forum again. And after this time there is not yet much progress.
Here are my questions about the details:
So what does it mean that "this sketch didn't work"?
What do you observe?
Does the code compile?
The sketch has quite an amount of serial output
Did you open the Serial Monitor in the Arduino-IDE?
What messages get printed to the serial monitor?
Best thing is to copy and paste the content of the serial monitor as a code-section too?
If you want to proceed faster in your project
You should really invest time to read
Investing this time will save much much more time than you had invested for reading this tutorial and writing down the fundamental details about you and your project.
best regards Stefan
