Programme keep reboot after connecting to MQTT
//Including the four libraries
#include <UniversalTelegramBot.h>
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include <PubSubClient.h>
//------- WiFi Settings -------
const char* ssid = "";
const char* password = "";
char thingsboardServer[] = "1";
#define TOKEN ""
// ------- Telegram config --------
#define BOT_TOKEN ""  // your Bot Token (Get from Botfather)
#define CHAT_ID "" // Chat ID of where you want the message to go (You can use MyIdBot to get the chat ID)
const int gasAnalogPin = 32;
long Bot_lasttime;
int bulk_messages_mtbs = 12000; // testing to delay 6sec to detecting another distance and which message been sent .
long lastMsg = 0;
int value = 0;
String val_str; //see last code block below use these to convert the float that you get back from DHT to a string =str
char val[50];
WiFiClientSecure espClient;
UniversalTelegramBot bot(BOT_TOKEN, espClient);
WiFiClient Client;
PubSubClient client(Client);
String ipAddress = "";
volatile bool telegramButton1PressedFlag = false;
volatile bool telegramButton2PressedFlag = false;
volatile bool telegramButton3PressedFlag = false;
volatile bool telegramButton4PressedFlag = false;
int status = WL_IDLE_STATUS;
unsigned long lastSend;
void setup_wifi() {
  delay(10);
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  randomSeed(micros());
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Create a random client ID
    String clientId = "ESP32Client-";
    clientId += String(random(0xffff), HEX);
    // Attempt to connect
    Serial.print("Connecting to ThingsBoard node ...");
    // Attempt to connect (clientId, username, password)
    if ( client.connect("ESP32 Device", TOKEN, NULL) ) {
      Serial.println( "[DONE]" );
      Serial.print( "[FAILED] [ rc = " );
      Serial.print( client.state() );
      Serial.println( " : retrying in 5 seconds]" );
      // Wait 5 seconds before retrying
      delay( 5000 );
pinMode(gasAnalogPin, INPUT);
setup_wifi();
client.setServer( thingsboardServer, 1883 );
lastSend = 0;
void sendTelegramMessage1() {
  String message = "Air was good @ 27 Mandai Estate Meeting Room!";
  if(bot.sendMessage(CHAT_ID, message, "Markdown")){
    Serial.println("TELEGRAM Message 1 Successfully sent");
void sendTelegramMessage2() {
  String message2 = "Air was poor, please turn on the aircondition fan @ 27 Mandai Estate Meeting Room!";
  if(bot.sendMessage(CHAT_ID, message2, "Markdown")){
    Serial.println("TELEGRAM Message 2 Successfully sent");
void sendTelegramMessage3() {
  String message3 = "Air was bad, please leave the room @ 27 Mandai Estate Meeting Room!";
  if(bot.sendMessage(CHAT_ID, message3, "Markdown")){
    Serial.println("TELEGRAM Message 3 Successfully sent");
void sendTelegramMessage4() {
  String message4 = "Air was terrible, please emergency evaculation @ 27 Mandai Estate Meeting Room!";
  if(bot.sendMessage(CHAT_ID, message4, "Markdown")){
    Serial.println("TELEGRAM Message 4 Successfully sent");
  if (!client.connected()) {
    reconnect();
  client.loop();
  float myfloat;
  float V0 = 750;
  float Rs = 0;
  float R0 = 0;
  float Voltage;
  float Vout = 1183;
  float ratio = 0;
  static bool value_reach = false;
  static bool value_reach2 = false;
           R0 = ((20000*5000/V0)-40000);
           Rs = ((20000*5000/analogRead(gasAnalogPin))-40000);
  ratio = Rs/R0; //Replace R0 with the value found using the sketch above
    Serial.println(R0);
    Serial.println(Rs);
    Serial.println(ratio); // How to calculate PPM?
    Serial.println("ratio");
  val_str = String(ratio); //converting ftemp (the float variable above) to a string
  val_str.toCharArray(val, val_str.length() + 1); //packaging up the data to publish to mqtt whoa...
  // Prepare a JSON payload string
  String payload = "{";
  payload += "\"val\":"; payload += val; payload += ",";
  payload += "}";
  // {"ts":1451649600512, "values":{"key1":"value1", "key2":"value2"}};
  // Send payload
  char attributes[100];
  payload.toCharArray( attributes, 100 );
  client.publish( "v1/devices/me/telemetry", attributes );
  Serial.println( attributes );
  if (ratio > 1.00) {                  //good stage 1
       Serial.println("checking ratio (1) again");
       delay(3000);
       if(!value_reach)
                    if(ratio > 1.00){
                         Serial.println("Send notification 1 to Telegram");
                         sendTelegramMessage1();
                         value_reach = true;
                         Bot_lasttime = 0;
} else if (ratio > 0.50 && ratio < 1.00) {        //bad   stage 2
            Serial.println("checking ratio (2) again");
            delay(3000);
            if(value_reach)
                         if(ratio > 0.50 && ratio < 1.00){
                              Serial.println("Send notification 2 to Telegram");
                              sendTelegramMessage2();
                              Bot_lasttime = 0;
} else if (ratio > 0.10 && ratio <0.50){        //poor  stage 3
            Serial.println("checking ratio (3) again");
            delay(3000);
            if(!value_reach2)
                                 Serial.println("Send notification 3 to Telegram");
                                 sendTelegramMessage3();
                                 value_reach2 = true;
                                 Bot_lasttime = 0;
} else if (ratio < 0.10){        //terrible stage 4
            Serial.println("checking ratio (4) again");
            delay(3000);
            if(value_reach2)
                          if (ratio < 0.10){
                                Serial.println("Send notification 4 to Telegram");
                                sendTelegramMessage4();
                                Bot_lasttime = 0;
After connecting up my think board server , my esp32 will reboot automatically .
Serial monitor shown :"Attempting MQTT connection...Connecting to ThingsBoard node ...[DONE] Guru Meditation Error: Core 1 panic'ed (Integer Divide By Zero). Exception was unhandled. Core 1 register dump: PC : 0x400d2162 PS : 0x00060430 A0 : 0x800d68f4 A1 : 0x3ffb1f00 A2 : 0x05f5e100 A3 : 0x3ffc0b98 A4 : 0x00000020 A5 : 0x80000020 A6 : 0x00000000 A7 : 0x3ffba3d8 A8 : 0x800d215c A9 : 0x3ffb1ee0 A10 : 0x00000000 A11 : 0x47b64aaa A12 : 0x00003a98 A13 : 0x00000cee A14 : 0x00000001 A15 : 0x00000000 SAR : 0x0000001c EXCCAUSE: 0x00000006 EXCVADDR: 0x00000000 LBEG : 0x400d602d LEND : 0x400d6039 LCOUNT : 0x00000000 Backtrace: 0x400d2162:0x3ffb1f00 0x400d68f1:0x3ffb1fb0 0x4008eab5:0x3ffb1fd0"
Suppose that analogRead() returns 0. Do you REALLY think that it is a good idea to divide by 0?
The Guru certainly doesn't.
PaulS:
thanks paul . i will make it store as a valuable the divide the valuable
That won't help, if the "valuable" contains 0.
What it will allow you to do, though, is test the value in the variable, and divide, or not, as appropriate.
PaulS:
PaulS:
yup,thats not working .
 float V0 = 750;
  float Rs = 0;
  float R0 = 0;
  float Voltage;
  float Vout = 1183;
  float ratio = 0;
  float h = analogRead(gasAnalogPin);
        Rs = ((20000*5000/gasAnalogPin)-40000);
  ratio = Rs/R0; //Replace R0 with the value found using the sketch abovefloat V0 = 750;
  String Val = String(ratio);
  // Just debug messages
  Serial.println(Rs);
  Serial.print( "Sending ratio : [" );
  Serial.print( ratio ); Serial.print( "," );
  Serial.print( "]   -> " );
It seems pointless to divide by a pin number.
