Programme with Led
good evening everyone I want to make a program to light a green and red led with a condition to compare to a threshold on 5 values ​​and I have the following error
Please do not post pictures of code and errors
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
As @UKHeliBob said please post your entire code using code blocks.
It appears that you intended for the digitalWrite() calls that follow the if to be executed if the if condition is true. You did not surround those digitalWrite() calls with curly braces so the compiler assumed you only wanted to execute the first digitalWrite() and then considered the else to have no matching if.
thank you so much the programme work perfectly :grinning:
