programmer is not responding, chinese nano clone with ch340G chip
Verbose output from uploading:
Sketch uses 926 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Users\Ales\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\Ales\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b57600 -D -Uflash:w:C:\Users\Ales\AppData\Local\Temp\arduino_build_761716/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\Ales\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
         Using Port                    : COM4
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 2
         Firmware Version: 1.16
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\Ales\AppData\Local\Temp\arduino_build_761716/Blink.ino.hex"
avrdude: writing flash (926 bytes):
Writing | avrdude: stk500_recv(): programmer is not responding
################################################## | 100% 12.95s
avrdude: 926 bytes of flash written
avrdude: verifying flash memory against C:\Users\Ales\AppData\Local\Temp\arduino_build_761716/Blink.ino.hex:
avrdude: load data flash data from input file C:\Users\Ales\AppData\Local\Temp\arduino_build_761716/Blink.ino.hex:
avrdude: input file C:\Users\Ales\AppData\Local\Temp\arduino_build_761716/Blink.ino.hex contains 926 bytes
avrdude: reading on-chip flash data:
Reading | #########################Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
######################### | 100% 0.22s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
         0xff != 0x0c
avrdude: verification error; content mismatch
avrdude done.  Thank you.
Board is set to "Arduino nano"
Processor to "AtMega328P (Old bootloader)"
COM is set to "COM4". Windows shows COM4 as USB-SERIAL CH340
My board is Arduino nano with Atmega328P-AU processor and CH340G chip.
It was working correctly until now. While uploading code, led 13 blinks 3 times fast, then it periodicaly blinks (every second) until rx and tx leds start to blink (for very short time), and then led 13 starts to periodicaly blink again. Sometimes when I hold reset button I manage to upload code.
What I tried: Reinstalling ide, downgrading board library to older versions, trying different usb ports, restarting pc, changing processor to atmega328p with new bootloader
What could be wrong?
Edit:
I tried uploading from phone, same problem. So its not related to my pc.
Arduino is disconnected from circuit, TX and RX are not connected to anything.
Tried loopback test. I did received my message back.
Everything according your description seems correct except one thing - obstacle with the reset which you mentioned. It leads me to suspect the reset signal.
Check your boar, reset signal path for any damages. You can try to connect LED with resistor in series to reset pin for test. Reset pulse is 200ms so it should be visible.
Yes, its probably broken auto reset. Reset pin is whole time of uploading high. (or atleast my eyes did not registered any blink). Traces are ok, but not sure about CH340G chip and capacitor between processor and this chip.
