I finished compiling a code, but whenever i try to upload the code it says
Sketch uses 4,766 bytes (14%) of program storage space. Maximum is 32,256 bytes.
Global variables use 396 bytes (19%) of dynamic memory, leaving 1,652 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xdf
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xdf
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xdf
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xdf
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xdf
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xdf
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xdf
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xdf
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xdf
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xdf
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
My code is-
#include <AFMotor.h>
#define trigPin 12
#define echoPin 13
AF_DCMotor motor1(1,MOTOR12_64KHZ);
AF_DCMotor motor2(2, MOTOR12_8KHZ);
Serial.println("Motor test!");
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
motor1.setSpeed(105);
motor2.setSpeed (127.5);
long duration, distance;
digitalWrite(trigPin, LOW); // Added this line
delayMicroseconds(2); // Added this line
digitalWrite(trigPin, HIGH);
// delayMicroseconds(1000); Removed this line
delayMicroseconds(10); // Added this line
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
if (distance < 25) { // This is where the LED On/Off happens
Serial.println ("Close Obstacle detected!" );
Serial.println ("Obstacle Details:");
Serial.print ("Distance From Robot is " );
Serial.print ( distance);
Serial.print ( " CM!");
Serial.println (" The obstacle is declared a threat due to close distance. ");
Serial.println (" Turning !");
motor1.run(FORWARD);
motor2.run (BACKWARD);
else {
Serial.println ("No obstacle detected. going forward");
delay (15);
motor2.run(FORWARD);
I am using a arduino uno board and i have tried unplugging the board from the computer, pushing the reset button before uploading, tacking everything off the board, and closing the code and opening up again.
