I'm not being able to upload sketches to my Arduino UNO.
This happened after I tried to play some tunes (using the PCM library) on a 8ohm, 1/2 W speaker connected between ground and PIN 11 (there was a 155ohm resistor between pin 11 and the speaker).
- Arduino UNO rev3
- Arduino IDE 1.6.3
- Mac OSX 10.10
- Serial loop test passed OK
- Board / Port detected OK by the IDE
- Using a second Arduino UNO I have, the blink sketch uploaded OK. (I don't want to try the same sketch / speaker connection on the second Arduino UNO just in case)
Is it possible that the connection I made fried my Arduino? Any hints?
This is the IDE log:
Arduino: 1.6.3 (Mac OS X), Board: "Arduino Uno"
Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
/Users/javier/Library/Arduino15/packages/arduino/tools/avrdude/6.0.1-arduino2/bin/avrdude -C/Users/javier/Library/Arduino15/packages/arduino/tools/avrdude/6.0.1-arduino2/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem26221 -b115200 -D -Uflash:w:/var/folders/sf/gtkn2jx13yb5j8tskdkcwmzc0000gn/T/build6551271325928109776.tmp/Blink.cpp.hex:i
avrdude: Version 6.0.1, compiled on Mar 19 2015 at 11:00:01
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Users/javier/Library/Arduino15/packages/arduino/tools/avrdude/6.0.1-arduino2/etc/avrdude.conf"
User configuration file is "/Users/javier/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem26221
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
enabled in File > Preferences.
