Programmer is not responding (MAC)
Hello,
So my Arduino was always working but since today it keeps saying this:
'Warning: platform.txt from core 'Arduino AVR Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
De schets gebruikt 450 bytes (1%) programma-opslagruimte. Maximum is 32.256 bytes.
Globale variabelen gebruiken 9 bytes (0%) van het dynamisch geheugen. Resteren 2.039 bytes voor lokale variabelen. Maximum is 2.048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Probleem bij het uploaden naar het board. Zie http://www.arduino.cc/en/Guide/Troubleshooting#upload voor suggesties.'
It's so annoying and I don't know what to do, I can only choose one port the /dev/cu.Bluetooth-Incoming-Port.
The board I'm using is selected as: Arduino Genuine Uno.
When I connect the USB it turns on, and the LED's on the Arduino SLOWLY turns off.
Can someone please help me, because I can't fix it and I really don't know the problem.
Help would be appreciated a lot.
Best regards Niels.
Hello,
My brother fixed the problem;
The circuit I built with the LCD was wrong, the - and +, it was supposed to be + and -.
