Programmer is not responding STK errors
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
Sketch uses 3244 bytes (10%) of program storage space. Maximum is 32256 bytes.
Global variables use 256 bytes (12%) of dynamic memory, leaving 1792 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\TEMP\AppData\Local\Temp\arduino_build_121381/arduino.ino.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x3e
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x3e
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x3e
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x3e
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x3e
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x3e
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x3e
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x3e
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x3e
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x3e
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
@blehblehleh
TOPIC SPLIT
PLEASE DO NOT HIJACK / NECRO POST !
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
(deleted)
