Programmer is not responding
I connected the Arduino UNO at the PC for the first time and the LED L blinking. I tried to upload to the first example Blink. I always receive the same error:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd3
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xd3
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xd3
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xd3
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xd3
Problema di caricamento sulla scheda. Guarda http://www.arduino.cc/en/Guide/Troubleshooting#upload per suggerimenti
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xd3
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xd3
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd3
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xd3
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xd3
How can i fix this?
(deleted)
I used windows 10, with the genuino starter kit, so i have a genuino uno. I bought it on ebay
pallonz91:
Just because its from Ebay does not mean its a real one.
I suspect its a clone and would require the Chinese drivers HERE
Also which IDE are you using as it helps people to help you.
the error is
Arduino: 1.6.9 Hourly Build 2016/03/17 01:33 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 450 bytes (1%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xb7
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xb7
I used the
OS -> Windows 7,
COMport -> COM8
Board -> Arduino UNO r3
Programmer -> USBasp
please help me to solve this problem
I had the same problem. I used a USB 3.0 Port and the same Error occured. After using a USB 2.0 Port the problem was solved.
Hope it helps someone. And for China Arduinos you may have to install another USB Driver. Like me the CH340.
Lg DomeE__
