Programmer not responding. Please help.
When I try to upload a program to my arduino, it takes a long time in process, doesn't upload and shows the following errors.
Arduino: 1.6.3 (Windows 8.1), Board: "Arduino Uno"
Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xed
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xed
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xed
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xed
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xed
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xed
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xed
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xed
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xed
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xed
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
This report would have more information with "Show verbose output during compilation" enabled in File > Preferences.
What to do?
To help I will need more information. One such piece of information is the type board you are using (a link to where it was purchased would also be helpful). Please provide me with answers to the following two questions as well.
  1. Does the device pass the loopback test? A link to the instructions for this can be found at the top of this sub-forum.
  2. Is the board properly bootloaded? The easiest way to check for the presence of the bootloader (on most AVR based Arduinos) is to observe the 'L' led when your board is reset or just being powered on. If the bootloader is present the led should blink a few times rapidly before running the sketch that is currently uploaded.
