So, i got my Arduino starter kit yesterday morning. All day yesterday and most of today i've spent on trying to upload the "Blink" program without any luck.
I'm running the Arduino uno board, the latest software from Arduinos website, Mac OS X 10.11.1
When i plug in the board the "ON" LED lights up and the LED marked "L" lights up and blinks a few times. The "L" LED is then holding a steady light for a moment and then blinking a few times , then holding a steady light, blinking a few times... And so on.
In the Arduino software i got the "Arduino UNO" selected as my board.
The port i got selected is called /dev/tty.usbmodemFA131
that port is not available until i plug in my board.
When i try to load the "Blink" program the "L" LED is holding a steady light.
and this comes up:
avrdude: Version 6.0.1, compiled on Jan 15 2015 at 12:42:51
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Users/johan/Downloads/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/johan/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.usbmodemFA131
Using Programmer : arduino
Overriding Baud Rate : 115200
It just stays like that for quite some time (sometimes even freezes), then this pups up:
vrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x10
avrdude: stk500_getsync(): can't communicate with device: resp=0x14
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x10
avrdude done. Thank you.
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x10
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x10
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x10
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x10
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x10
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x10
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x10
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x10
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x10
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
Problem vid uppladdning till brädan. Se http://www.arduino.cc/en/Guide/Troubleshooting#upload för förslag.
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
PLEASE HELP ME! I've been to the end of internet in search for a solution but nothing worked. It's probably something simple but i'm new at this so..
I've been trying different drivers, pressing the reset button at various moments, rebooting with and without the board plugged in. I'm tired of google.
There's also a tab under "Tools" that says "programmer" i think (i got the software in swedish)
Anyhow..
I've been trying different options, "AVRISP Mk2", "USBasp" and so on with some different results. But the one thing i can see to be in common is the message:
resp=0x10avrdude: stk500_recv(): programmer is not responding
Thank you!
