My arduino's been working fine until recently whenever I try to upload code. I checked that its connected to the right port and I even tried a different USB cable but nothing seems to work! Does anyone know what could be going wrong?
Arduino: 1.8.10 (Mac OS X), Board: "Arduino/Genuino Uno"
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/Users/sammyofer/Desktop/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.-C/Users/sammyofer/Desktop/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf
-v -patmega328p -carduino -P/dev/cu.usbmodem14101 -b115200 -D -Uflash:w:/var/folders/04/frwhnb_9421gymhj27r4jkg00000gn/T/arduino_build_162883/sketch_nov01a.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/sammyofer/Desktop/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/sammyofer/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem14101
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
option enabled in File -> Preferences.
