Hi
I'm getting a weird "programmer is not receiving error" with my UNO R2, I've looked for possible solutions but none helped. Most of them couldn't upload the sketch even once, I can upload a few times before the error occurs.
This problem started after I upgraded my computer to new Gigabyte Haswell motherboard. After a few uploads (about 3, 4 uploads) the programmer is not responding anymore. Sometimes the programmer stops responding mid upload. The only solution I've found is to reconnect the USB cable. After that it works again for a few uploads. I believe there is something happens on the OS level when "upload" is pressed since this is only happening in Ubuntu 13.10, on windows it works fine. I've followed the installation guide, is there anything else that should be set in Ubuntu?
I've tried as many different cables as I could find and all the USB ports on the motherboard, changing baud rate doesn't help, same with 1.5.5 beta IDE. Also If the upload is successful, serial monitor will work just fine. Did anybody else had a similar problem, what would be a possible solution?
After a few successful uploads, this is the error returned
avrdude: Version 5.11.1, compiled on Apr 28 2013 at 18:46:46
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/usr/share/arduino/hardware/tools/avrdude.conf"
User configuration file is "/home/me/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM0
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: ser_recv(): programmer is not responding
and with "shift+upload"
Using Port : usb
Using Programmer : stk500v2
avrdude: usbdev_open(): did not find any USB device "usb"
Thanks
