Anybody have one of these?
I have an older one, 2011, Win107Pro won't recognize it, am looking for a replacement I can recommend. $4 seems like a deal, if they work.
I've uised ones that look like that without issue.
I recommend loading the PeterVH/bperrypap 5/18 firmware on them - it fixes the occasional issues getting the chip into programming mode.
These are the ones I use:
www.ebay.com/itm/252816932864
The logo that's blurred out on the picture says "Baite". I'm running Windows 7 Pro, 64 and 32 bit. The stock firmware is ok for most uses but with PeterVH/bperrybap's updated firmware installed on them I haven't found anything they can't do:
I'm using the libusbk driver installed using Zadig:
http://zadig.akeo.ie/
I couldn't make them work with Arduino's build of AVRDUDE 6.3 using the libusb-win32 driver that used to work fine with previous AVRDUDE versions.
You can get them in 10 pin but I have no use for the serial lines and prefer not to have to deal with an adapter.
Ok, thanks for the feedback. If I could get Win7 to recognize mine perhaps I could try that firmware. It's just an Atmega8A chip. Could use my press-fit adapter and load it I suppose.
