Programming 4x4x4 RGB Cube
Hey there,
I have to do a project for school, where I have to program a 4x4x4 RGB LED cube so that I can choose the colors.
The model is Iduino AD060, which needs which needs an Iduino ST1149 driver board. The cube was already built by my teacher. I have absolutely no clue how that is done so I could only give you this information.
Manual of the cube: http://www.produktinfo.conrad.com/datenblaetter/1500000-1599999/001525427-an-01-en-RGB_CUBE_KIT_WITHOUT_DRIVER_BOARD.pdf
A lot of it is about building the cube, but I don't need that.
Manual of the driver board: http://www.produktinfo.conrad.com/datenblaetter/1500000-1599999/001525450-an-01-en-8_X_8_RGB_MATRIX_DISPLAY_TREIBER_BOARD.pdf
I don't know if the code there has anything to do with my project, though.
At the end of the manual of the cube, there is a sample code which I copied, but there are various error messages when I compile it. I hope I installed the Colorduino library correctly. Here's the code:
#include <Colorduino.h>
typedef struct
  unsigned char r;
  unsigned char g;
  unsigned char b;
} ColorRGB;
typedef struct
  unsigned char h;
  unsigned char s;
  unsigned char v;
} ColorHSV;
unsigned char plasma[ColorduinoScreenWidth][ColorduinoScreenHeight];
long paletteShift;
//Converts an HSV color to RGB color
void HSVtoRGB(void *vRGB, void *vHSV)
  float r, g, b, h, s, v; //this function works with floats between 0 and 1
  float f, p, q, t;
  int i;
  ColorRGB *colorRGB=(ColorRGB *)vRGB;
  ColorHSV *colorHSV=(ColorHSV *)vHSV;
  h = (float)(colorHSV->h / 256.0);
  s = (float)(colorHSV->s / 256.0);
  v = (float)(colorHSV->v / 256.0);
  //if saturation is 0, the color is a shade of grey
  if(s == 0.0)
    b = v;
    g = b;
    r = g;
  //if saturation > 0, more complex calculations are needed
    h *= 6.0; //to bring hue to a number between 0 and 6, better for the calculations
    i = (int)(floor(h)); //e.g. 2.7 becomes 2 and 3.01 becomes 3 or 4.9999 becomes 4
    f = h - i;//the fractional part of h
    p = (float)(v * (1.0 - s));
    q = (float)(v * (1.0 - (s * f)));
    t = (float)(v * (1.0 - (s * (1.0 - f))));
    switch(i)
      case 0: r=v; g=t; b=p; break;
      case 1: r=q; g=v; b=p; break;
      case 2: r=p; g=v; b=t; break;
      case 3: r=p; g=q; b=v; break;
      case 4: r=t; g=p; b=v; break;
      case 5: r=v; g=p; b=q; break;
      default: r = g = b = 0; break;
  colorRGB->r = (int)(r * 255.0);
  colorRGB->g = (int)(g * 255.0);
  colorRGB->b = (int)(b * 255.0);
float dist(float a, float b, float c, float d)
  return sqrt((c-a)*(c-a)+(d-b)*(d-b));
void plasma_morph()
  unsigned char x,y;
  float value;
  ColorRGB colorRGB;
  ColorHSV colorHSV;
  for(y = 0; y < ColorduinoScreenHeight; y++)
  for(x = 0; x < ColorduinoScreenWidth; x++)
      value = sin(dist(x + paletteShift, y, 128.0, 128.0) / 8.0)
      + sin(dist(x, y, 64.0, 64.0) / 8.0)
      + sin(dist(x, y + paletteShift / 7, 192.0, 64) / 7.0)
      + sin(dist(x, y, 192.0, 100.0) / 8.0);
      colorHSV.h=(unsigned char)((value) * 128)&0xff;
      colorHSV.s=255;
      colorHSV.v=255;
      HSVtoRGB(&colorRGB, &colorHSV);
      Colorduino.SetPixel(x, y, colorRGB.r, colorRGB.g, colorRGB.b);
  paletteShift++;
  Colorduino.FlipPage(); // swap screen buffers to show it
Function: Fill the frame with a color
Parameter:R: the value of RED. Range:RED 0~255
G: the value of GREEN. Range:RED 0~255
B: the value of BLUE. Range:RED 0~255
void ColorFill(unsigned char R,unsigned char G,unsigned char B)
  PixelRGB *p = Colorduino.GetPixel(0,0);
  for(unsigned char y=0;y<ColorduinoScreenWidth;y++)
    for(unsigned char x=0;x<ColorduinoScreenHeight;x++)
      p->r = R;
      p->g = G;
      p->b = B;
      p++;
  Colorduino.Init(); // initialize the board
  // compensate for relative intensity differences in R/G/B brightness
  // array of 6-bit base values for RGB (0~63)
  // whiteBalVal[0]=red
  // whiteBalVal[1]=green
  // whiteBalVal[2]=blue http://keyes-arduino.taobao.com
  unsigned char whiteBalVal[3] = {36,63,63}; // for LEDSEE 6x6cm round matrix
  Colorduino.SetWhiteBal(whiteBalVal);
  // start with morphing plasma, but allow going to color cycling if desired.
  paletteShift=128000;
  unsigned char bcolor;
  //generate the plasma once
  for(unsigned char y = 0;y < ColorduinoScreenHeight; y++)
  for(unsigned char x = 0; x < ColorduinoScreenWidth; x++)
    //the plasma buffer is a sum of sines
    bcolor = (unsigned char)(128.0 + (128.0 * sin(x*8.0 / 16.0))+ 128.0 + (128.0 * sin(y*8.0 / 16.0))) / 2;
    plasma[x][y] = bcolor;
  // to adjust white balance you can uncomment this line
  // and comment out the plasma_morph() in loop()
  // and then experiment with whiteBalVal above
  // ColorFill(255,255,255);
  plasma_morph();
I don't understand everything, I only have some experience with Gamemaker Studio, so this is something entirely new for me.
These are the error messages:
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
In file included from C:\Program Files (x86)\Arduino\libraries\Colorduino/Colorduino.h:44:0,
                 from C:\led_rgb_cube\led_rgb_cube.ino:1:
C:\Program Files (x86)\Arduino\libraries\Colorduino/ColorTools.h: In member function 'int ColorTools::RGBtoInt(void*)':
C:\Program Files (x86)\Arduino\libraries\Colorduino/ColorTools.h:206:40: warning: left shift count >= width of type
   return (((unsigned int)colorRGB->r)<<16) + (((unsigned int)colorRGB->g)<<8) + (unsigned int)colorRGB->b;
C:\led_rgb_cube\led_rgb_cube.ino: At global scope:
led_rgb_cube:7: error: conflicting declaration 'typedef struct ColorRGB ColorRGB'
 } ColorRGB;
C:\Program Files (x86)\Arduino\libraries\Colorduino/ColorTools.h:38:3: note: previous declaration as 'typedef struct ColorRGB ColorRGB'
 } ColorRGB;
led_rgb_cube:14: error: conflicting declaration 'typedef struct ColorHSV ColorHSV'
 } ColorHSV;
C:\Program Files (x86)\Arduino\libraries\Colorduino/ColorTools.h:44:3: note: previous declaration as 'typedef struct ColorHSV ColorHSV'
 } ColorHSV;
C:\led_rgb_cube\led_rgb_cube.ino: In function 'void ColorFill(unsigned char, unsigned char, unsigned char)':
led_rgb_cube:102: error: 'PixelRGB' was not declared in this scope
led_rgb_cube:102: error: 'p' was not declared in this scope
exit status 1
I really need help with what I have to do now. All I need to do is setting the colors of the individual to what I want.
Edit: Sorry if this is not the right page but it's my first time on this forum.
You must have, since the code that doesn't compile is in the Colorduino library.
What you didn't do was post a link to the Colorduino library.
The PDF file contains a link to the Colorduino library, which has a method, GetPixel() that returns a pointer to a ColorRGB instance. Why does your code define the type as pointer to PixelRGB?
Thanks for your answer, i got rid of the error messages somehow. im having trouble uploading the code to the board but im gonna ask this somewhere else.
