Programming 5 buttons and 2 encoders
Hey guys I hope this topic finds everyone well.
I am trying to do something that seems simple but I am stumped as to how to code it.
I am looking to make a button box with 5 momentary buttons and 2 rotary encoders.
I have seen someone do this with a lot more buttons and encoders and I even have the sketch but it was done on a micro board and I would like to do a simpler version on a Nano board? Is this possible?
In the video he does a matrix but as I am going to be using only 5 buttons and 2 encoders I could just do the first row of buttons?
The sketch for the 32 buttons has this code -
#include <Keypad.h>
#include <Joystick.h>
#define ENABLE_PULLUPS
#define NUMROTARIES 4
#define NUMBUTTONS 24
#define NUMROWS 5
#define NUMCOLS 5
byte buttons[NUMROWS][NUMCOLS] = {
  {0,1,2,3,4},
  {5,6,7,8,9},
  {10,11,12,13,14},
  {15,16,17,18,19},
  {20,21,22,23},
struct rotariesdef {
  byte pin1;
  byte pin2;
  int ccwchar;
  int cwchar;
  volatile unsigned char state;
rotariesdef rotaries[NUMROTARIES] {
  {0,1,24,25,0},
  {2,3,26,27,0},
  {4,5,28,29,0},
  {6,7,30,31,0},
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
  // R_START (00)
  {R_START_M,            R_CW_BEGIN,     R_CCW_BEGIN,  R_START},
  // R_CCW_BEGIN
  {R_START_M | DIR_CCW, R_START,        R_CCW_BEGIN,  R_START},
  // R_CW_BEGIN
  {R_START_M | DIR_CW,  R_CW_BEGIN,     R_START,      R_START},
  // R_START_M (11)
  {R_START_M,            R_CCW_BEGIN_M,  R_CW_BEGIN_M, R_START},
  // R_CW_BEGIN_M
  {R_START_M,            R_START_M,      R_CW_BEGIN_M, R_START | DIR_CW},
  // R_CCW_BEGIN_M
  {R_START_M,            R_CCW_BEGIN_M,  R_START_M,    R_START | DIR_CCW},
#else
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
  // R_START
  {R_START,    R_CW_BEGIN,  R_CCW_BEGIN, R_START},
  // R_CW_FINAL
  {R_CW_NEXT,  R_START,     R_CW_FINAL,  R_START | DIR_CW},
  // R_CW_BEGIN
  {R_CW_NEXT,  R_CW_BEGIN,  R_START,     R_START},
  // R_CW_NEXT
  {R_CW_NEXT,  R_CW_BEGIN,  R_CW_FINAL,  R_START},
  // R_CCW_BEGIN
  {R_CCW_NEXT, R_START,     R_CCW_BEGIN, R_START},
  // R_CCW_FINAL
  {R_CCW_NEXT, R_CCW_FINAL, R_START,     R_START | DIR_CCW},
  // R_CCW_NEXT
  {R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
byte rowPins[NUMROWS] = {21,20,19,18,15};
byte colPins[NUMCOLS] = {14,16,10,9,8};
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
  JOYSTICK_TYPE_JOYSTICK, 32, 0,
  false, false, false, false, false, false,
  false, false, false, false, false);
  Joystick.begin();
  rotary_init();}
  CheckAllEncoders();
  CheckAllButtons();
void CheckAllButtons(void) {
      if (buttbx.getKeys())
       for (int i=0; i<LIST_MAX; i++)
           if ( buttbx.key[i].stateChanged )
            switch (buttbx.key[i].kstate) {
                    case PRESSED:
                    case HOLD:
                              Joystick.setButton(buttbx.key[i].kchar, 1);
                    case RELEASED:
                    case IDLE:
                              Joystick.setButton(buttbx.key[i].kchar, 0);
void rotary_init() {
  for (int i=0;i<NUMROTARIES;i++) {
    pinMode(rotaries[i].pin1, INPUT);
    pinMode(rotaries[i].pin2, INPUT);
    #ifdef ENABLE_PULLUPS
      digitalWrite(rotaries[i].pin1, HIGH);
      digitalWrite(rotaries[i].pin2, HIGH);
    #endif
unsigned char rotary_process(int _i) {
   unsigned char pinstate = (digitalRead(rotaries[_i].pin2) << 1) | digitalRead(rotaries[_i].pin1);
  rotaries[_i].state = ttable[rotaries[_i].state & 0xf][pinstate];
  return (rotaries[_i].state & 0x30);
void CheckAllEncoders(void) {
    unsigned char result = rotary_process(i);
    if (result == DIR_CCW) {
      Joystick.setButton(rotaries[i].ccwchar, 1); delay(50); Joystick.setButton(rotaries[i].ccwchar, 0);
    if (result == DIR_CW) {
      Joystick.setButton(rotaries[i].cwchar, 1); delay(50); Joystick.setButton(rotaries[i].cwchar, 0);
So I was thinking that my code just needs to read like below?
#include <Keypad.h>
#define NUMROTARIES 2
#define NUMBUTTONS 5
#define NUMROWS 1
#define NUMCOLS 1
{0,1,2,3,4},
byte pin1;
byte pin2;
int ccwchar;
int cwchar;
{0,1}
I was planning on wiring physically to A3 for the first part of the chain to all 5 momentary buttons then D14,16,10,9,8 for the other side of the button.
For the 2 Encoders I was thinking of going into pin 15 for push function then D14 and 16 for the opposite side of that circuit,
For the rotational function I was going to go TX, RX on the first one and then D2 and 3 on the second one?
I hope this makes sense and any help would be appreciated.
Many thanks
Darren
The Micro is a microcontroller board based on the ATmega32U4 which allows the Micro to appear to a connected computer as a mouse and keyboard, in addition to a virtual (CDC) serial / COM port.
The Nano does not have that capability
if your code depends on this, then that won't do.
J-M-L:
Ahh thanks for the reply that clears up something I was wondering as to how people make button boxes work on Consoles too, I shall get a Micro on order !
The other question then is will my code and placement on a micro board work for the 5 buttons and 2 rotaries?
Many thanks again
i'm using an esp32 to monitor 16 buttons, 2 encoders, several pots and a OLED display.
the 16 buttons are monitored using 8 pins as a matrix
i developed encoder code on an arduino using 2 interrupts. i don't believe the arduino had more than 2 interrupts (but has multiple change interrupts ???). any gpio on an esp32 can be used as an interrupt. you would need 4 for 2 encoders
there is no code, just array definitions and I don't know those types
but just as C++ stands, this is not correct
#define NUMROWS 1
#define NUMCOLS 1
  {0,1,2,3,4},
NUMCOLS as you define it should be 5
also this (comparing to the other def) feels incorrect too
  {0,1}
Please correct your post above and add code tags around code segments:
[code]`` [color=blue]// your code is here[/color] ``[/code].
It should look like this:// your code is here
(Also press ctrl-T (PC) or cmd-T (Mac) in the IDE before copying to indent your code properly)
J-M-L:
#define NUMROWS 1
#define NUMCOLS 1
  {0,1,2,3,4},
  {0,1}
Please correct your post above and add **code tags** around code segments:
`[code]`` [color=blue]// your code is here[/color] ``[/code]`.
It should look like this:`// your code is here`
Sorry first time adding code or asking for help on here, I shall update the post now with the full code at the top
See that’s the rotariesdef type definition
  byte pin1;
  byte pin2;
  int ccwchar;
  int cwchar;
you can’t have just 2 values to describe yours.
@daz1987
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
