Hi all! have two LED scrolling displays that I took apart to harvest the M500-7X80RG PCBs out of to turn into a stopwatch. I'm completely new to LED matrices and programming them. The only documentation online I've found to programming these displays is this GitHub repo. When I started to wire the display to my Arduino as shown and plugged the display into power, my Arduino Uno immediately got really hot and I unplugged it. The power supply going into the display outputs 5V at a max of 6A.
My question is, where do I start and how do I go about programming this? As I've said before, I've found almost no documentation online for a method to do so.
Here's a pic of the PCB:
Also, I rewired the entire thing (again) and this time nothing happened, nothing heated up at all. The power is supplied through the barrel jack in on the PCB. I don't have a schematic of the PCB, nor could I find one anywhere. The only connections I've made myself are the connections described from the PCB to the Arduino.
Not sure what you mean by that. The barrel definitely is supplying power to the PCB. I'm not sure what it connects to on the PCB though (as I've said, I can find almost no documentation for this PCB anywhere).
When the cable is plugged in, I can connect a cable from the positive terminal on the connector to one of the LED matrices and they light up. Additionally, when I have the original controller (the one that came with the sign) attached to the PCB, when it is plugged in it beeps and makes noise.
