Hi i am trying to make a 360 servo spin continuous with an on off button, i would appreciate it if someone can make a code i can use for that.
Please try to code this yourself
Look at the examples in the IDE
Learn to read the state of an input pin
A continuous rotation servo, if that is what you have, will continue to spin once you write a value to it and stop when you write zero (or something close) to it
Some servo test code you can use to understand how your continuous rotation servo operates.
// zoomkat 7-30-10 serial servo test
// type servo position 0 to 180 in serial monitor
// for writeMicroseconds, use a value like 1500
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo;Â // create servo object to control a servo
 myservo.attach(9);
 while (Serial.available()) {
  if (Serial.available() >0) {
   char c = Serial.read(); //gets one byte from serial buffer
   readString += c; //makes the string readString
   delay(3);
 if (readString.length() >0) {
  Serial.println(readString);
  int n = readString.toInt();
  Serial.println(n);
  myservo.writeMicroseconds(n);
  //myservo.write(n);
  readString="";
