Programming a flex sensor to RGB LED's
I feel like I am almost there, there is just something wrong. The red LED turns off when it goes under 242, but I don't know why the LED won't change to yellow and green.
  Analog input, analog output, serial output
 Reads an analog input pin, maps the result to a range from 0 to 255
 and uses the result to set the pulsewidth modulation (PWM) of an output pin.
 Also prints the results to the serial monitor.
 The circuit:
 * potentiometer connected to analog pin 0.
   Center pin of the potentiometer goes to the analog pin.
   side pins of the potentiometer go to +5V and ground
 * LED connected from digital pin 9 to ground
 created 29 Dec. 2008
 modified 9 Apr 2012
 by Tom Igoe
 This example code is in the public domain.
// These constants won't change.  They're used to give names
// to the pins used:
const int analogInPin = A0;  // Analog input pin that the flex sensor is attached to
const int analogOutPin = 9; // Analog output pin that the LED is attached to
int sensorValue = 0;        // value read from the flexsensor
int outputValue = 0;        // value output to the PWM (analog out)
int redPin   = 7;   // Red LED,   connected to digital pin 5
int greenPin = 6;  // Green LED, connected to digital pin 6
int bluePin  = 5;  // Blue LED,  connected to digital pin 7
  // sets the pins as output
  pinMode(redPin,   OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin,  OUTPUT);
  // initialize serial communications at 9600 bps:
void outputColor(int red, int green, int blue) {
  analogWrite(redPin, red);
  analogWrite(bluePin, blue);
  analogWrite(greenPin, green);
  // read the analog in value:
  sensorValue = analogRead(analogInPin);
  // map it to the range of the analog out:
  outputValue = map(sensorValue, 0, 1023, 0, 255);
  // change the analog out value:
  analogWrite(analogOutPin, outputValue);
  // print the results to the serial monitor:
  Serial.print("sensor = " );
  Serial.print(sensorValue);
  Serial.print("\t output = ");
  Serial.println(outputValue);
  // wait 2 milliseconds before the next loop
  // for the analog-to-digital converter to settle
  // after the last reading:
  delay(2);
  flexvalue();
void flexvalue() {
  int sensorValue = analogRead(A0);
   if (sensorValue > 130 && sensorValue < 240 ){
      digitalWrite(bluePin, LOW);
      digitalWrite(redPin, LOW);
      digitalWrite(greenPin, HIGH);
    else if (sensorValue > 159 && sensorValue < 241){
      digitalWrite(redPin, HIGH);
     else if (sensorValue > 242 && sensorValue < 400){
      digitalWrite(greenPin, LOW);
The if ranges were overlapping and unnecessary "complex"
try this as a starter (use CTRL-T to auto align the code)
removed unneeded comments and added some (in capitals to see them easily)
const int redPin   = 7;
const int greenPin = 6;
const int bluePin  = 5;
  delay(2);
  flexvalue();
void flexvalue()
  // int sensorValue = analogRead(A0); // WAS ALREADY READ !
  if (sensorValue < 200 )
  else if (sensorValue < 300)
  else if (sensorValue < 400)
  else  // ADDED THIS CASE TO CATCH ALL NON COVERED VALUES IN YOUR CODE
    digitalWrite(bluePin, HIGH);
