Programming a Nightlight with Wifi Function
Since it gets dark so quickly currently, I want to have a little night light in every room.
I thought about a simple setup: 4 Microcontroller with a LED that can be turned out with on single button.
Ideally, all the devices are both servers and clients, but I dont know if that works. So I tried to program a host device with the button and 4 client devices with just the LEDs.
For the host device, I used the code from ESP32 Web Server: Controlling LED Lights : 7 Steps - Instructables
and removed the OLED screen:
// Load Wi-Fi library
#include <WiFi.h>
#include <Wire.h>
// Replace with your network credentials
const char* ssid = "+";
const char* password = "+";
// Set web server port number to 80
WiFiServer server(80);
// Variable to store the HTTP request
String header;
// Auxiliar variables to store the current output state
String LED1State = "off";
String LED2State = "off";
// Assign output variables to GPIO pins
const int LED1 = 39;
const int LED2 = 40;
int flag = 0;
// Current time
unsigned long currentTime = millis();
// Previous time
unsigned long previousTime = 0;
// Define timeout time in milliseconds (example: 2000ms = 2s)
const long timeoutTime = 2000;
  // Initialize the output variables as outputs
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  // Set outputs to LOW
  digitalWrite(LED1, LOW);
  digitalWrite(LED2, LOW);
  // Connect to Wi-Fi network with SSID and password
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  // Print local IP address and start web server
  Serial.println("");
  Serial.println("WiFi connected.");
  Serial.println("IP address: ");
  server.begin();
void loop(){
  WiFiClient client = server.available();   // Listen for incoming clients
  if (client) {                             // If a new client connects,
    previousTime = currentTime;
    Serial.println("New Client.");          // print a message out in the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected() && currentTime - previousTime <= timeoutTime) {  // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        header += c;
        if (c == '\n') {                    // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("Content-type:text/html");
            client.println("Connection: close");
            client.println();
            // turns the GPIOs on and off
            if (header.indexOf("GET /26/on") >= 0) {
              Serial.println("GPIO 26 on");
              LED1State = "on";
              digitalWrite(LED1, HIGH);
            } else if (header.indexOf("GET /26/off") >= 0) {
              Serial.println("GPIO 26 off");
              LED1State = "off";
               } else if (header.indexOf("GET /27/on") >= 0) {
              Serial.println("GPIO 27 on");
                       LED2State = "on";
              digitalWrite(LED2, HIGH);
            } else if (header.indexOf("GET /27/off") >= 0) {
              Serial.println("GPIO 27 off");
              LED2State = "off";
            // Display the HTML web page
            client.println("<!DOCTYPE html><html>");
            client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
            client.println("<link rel=\"icon\" href=\"data:,\">");
            // CSS to style the on/off buttons
            // Feel free to change the background-color and font-size attributes to fit your preferences
            client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
            client.println(".button { background-color: #4CAF50; border: none; color: white; padding: 16px 40px;");
            client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
            client.println(".button2 {background-color: #555555;}</style></head>");
            // Web Page Heading
            client.println("<body><h1>ESP32 Web Server</h1>");
            // Display current state, and ON/OFF buttons for GPIO 26
            client.println("<p>GPIO 26 - State " + LED1State + "</p>");
            // If the output26State is off, it displays the ON button
            if (LED1State=="off") {
              client.println("<p><a href=\"/26/on\"><button class=\"button\">ON</button></a></p>");
              client.println("<p><a href=\"/26/off\"><button class=\"button button2\">OFF</button></a></p>");
            // Display current state, and ON/OFF buttons for GPIO 27
            client.println("<p>GPIO 27 - State " + LED2State + "</p>");
            // If the output27State is off, it displays the ON button
            if (LED2State=="off") {
              client.println("<p><a href=\"/27/on\"><button class=\"button\">ON</button></a></p>");
              client.println("<p><a href=\"/27/off\"><button class=\"button button2\">OFF</button></a></p>");
            client.println("</body></html>");
            // The HTTP response ends with another blank line
            client.println();
            // Break out of the while loop
          } else { // if you got a newline, then clear currentLine
            currentLine = "";
        } else if (c != '\r') {  // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
    // Clear the header variable
    header = "";
    // Close the connection
    client.stop();
    Serial.println("Client disconnected.");
    Serial.println("");
Which works perfectly fine, I just have to implement the button function, but I can currently control the LED with my webbrowser.
But then I wanted to program the client device, which should just takes the information of the server wether it should enable the LED or disable it.
I tried it with this code:
#include <WiFi.h>
#include <Wire.h>
String header;
int flag = 0;
// Current time
// Previous time
    Serial.print(".");
  Serial.println("");
void loop(){
    const uint16_t port = 80;
    const char * host = "192.168.101.208"; // ip or dns
    Serial.println(host);
        // Use WiFiClient class to create TCP connections
    WiFiClient client;
    if (!client.connect(host, port)) {
        Serial.println("Connection failed.");
        Serial.println("Waiting 5 seconds before retrying...");
        delay(5000);
        return;
              LED1State = "on";
              LED1State = "off";
                       LED2State = "on";
              LED2State = "off";
    Serial.println("");
and while it is connecting to the wifi, it does not turn on or off the LED like the server device does. Any anyone tell me what I did wrong and how I can fix it? Also, if that is the "best" solution for my idea or if programming wise it should be solved completely differently?
