programming a pir sensor using arduino
I need help with the code for programming a pir sensor
This forum is about programming the Arduino. Find the PIR sensor programming forum for help programming your sensor.
to sense and count 3 different objects.
What objects? Do you know what a PIR sensor senses?
Ditch that stupid code. You started from a crappy example.
Where are you counting the number of times the sensor has become HIGH? How can you expect to move the servo after the count reaches three if you don't count? If you don't determine that the sensor has changed state?
