Good afternoon, I'm having a bit of trouble with my most recent project.. I've posted once before, and i got a lot of help, although realizing later that it wasn't what i exactly needed, as the demands changed after.. Thing is, this time, I need a external reset button for my Arduino Mega ADK, and I know, it's a no brainer, connect a cable from the reset pin to a momentary switch, and the other side of the switch will be connected to the GND pin..
My issue is, my robotic arm doesn't have a claw, it uses a electromagnet.. And when i press reset, the electromagnet will also be disabled, and it shouldn't, because if I press the reset button "mid-work" the piece it carries will fall down..
By the way, I'm not using a regular stop button, because if I used "if's", the stop button will not stop the program "mid-function", only after it's done the function..
I also tried "interrupts" but delays won't work, and I know there is a way around it, but right now i don't have that much time to learn it..
I think I've explained it good enough.. I'll post my code below:
Thanks in advance!!
int const buttonPin = 21; //botão STOP
int const p1 = 40; // botão 1 ENTRADAS
int const p2 = 41; // botão 2
int const p3 = 42; // botão 3
int const p4 = 43; // botão 4
int const rodaresquerda = 44;
int const rodardireita = 45;
int const braco1frente = 46;
int const braco1tras = 47;
int const eletroimanon = 48;
int const eletroimanoff = 49;
int const antebracofrente = 50;
int const antebracotras = 51;
int const supelecfrente = 52;
int const supelectras = 53;
int const servo = 34; // SAIDAS
int const rotativomais = 33;
int const rotativomenos = 32;
int const bracomais = 31;
int const bracomenos = 30;
int const antebracomais = 29;
int const antebracomenos = 28;
int const suportegarramais = 27;
int const suportegarramenos = 26;
int const electro = 25;
int servotmp; //variáveis
int rotativomaistmp;
int rotativomenostmp;
int bracomaistmp;
int bracomenostmp;
int antebracomaistmp;
int antebracomenostmp;
int suportegarramaistmp;
int suportegarramenostmp;
int electrotmp;
bool servoFlag; //BANDEIROLAS
bool rotativomaisFlag;
bool rotativomenosFlag;
bool bracomaisFlag;
bool bracomenosFlag;
bool antebracomaisFlag;
bool antebracomenosFlag;
bool suportegarramaisFlag;
bool suportegarramenosFlag;
bool electroFlag;
pinMode (40, INPUT);
pinMode (41, INPUT);
pinMode (42, INPUT);
pinMode (43, INPUT);
pinMode (44, INPUT);
pinMode (45, INPUT);
pinMode (46, INPUT);
pinMode (47, INPUT);
pinMode (48, INPUT);
pinMode (49, INPUT);
pinMode (50, INPUT);
pinMode (51, INPUT);
pinMode (52, INPUT);
pinMode (53, INPUT);
pinMode (34, OUTPUT);
pinMode (33, OUTPUT);
pinMode (32, OUTPUT);
pinMode (31, OUTPUT);
pinMode (30, OUTPUT);
pinMode (29, OUTPUT);
pinMode (28, OUTPUT);
pinMode (27, OUTPUT);
pinMode (26, OUTPUT);
pinMode (25, OUTPUT);
if (digitalRead(eletroimanon) == HIGH) { //botão start está feito
primeiropasso:
if (digitalRead(reset) == HIGH){
digitalWrite(suportegarramais, HIGH);
delay (2000);
segundopasso:
digitalWrite(suportegarramais, LOW);
delay(2000);
terceiropasso:
digitalWrite(suportegarramenos, HIGH);
delay(2000);
quartopasso:
digitalWrite(suportegarramenos, LOW);
delay(2000);
