I also want to know how to use that programmer. Should I just fit in my ATMega328P into the Microcontroller slot you see in the picture on Ebay (The site is in the above link).
VishalSubramanyam:
I have a doubt. I want to know whether programming a standalone Arduino Bootloader loaded ATMega328P with Arduino C language instead of the standard C language would work.
Yes.
VishalSubramanyam:
You can program atmega328p with Arduino C. (First set the fuses).
To program with programmmer conect the atmega328p to the conector (not the socket/slot, dont remove that microcontroller because its the core of the programmer). The conector is called avr isp and it has two versions, isp 10 pins and isp 6 pins. Both work the same way, just google "avr isp pinout", and then google "atmega328p" pinout . You have to connect MISO, MOSI, SCK, VCC , GND and RESET.
int led = 13;
setup() {
pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
