programming ADS 1232 without spi (mega2560)
Hello
I’m having trouble interfacing ADS1232 chip with my Arduino MEGA2560.
I have this so far
int data = 9;
int sclk = 10;
int pdwn = 11;
int clkin = 12;
int SPEED = 13;
  analogWrite (A0, 3);
  analogWrite (A1, 500);
  pinMode(SPEED, OUTPUT);
  pinMode(clkin, OUTPUT);
  pinMode(data, INPUT);
  pinMode(sclk, OUTPUT);
  pinMode(pdwn, OUTPUT);
  digitalWrite(SPEED, LOW);
  digitalWrite(clkin, LOW);
  digitalWrite(data, HIGH);
    digitalWrite(sclk, HIGH); //enter standby
    delay(100);
    digitalWrite(sclk, LOW); //wake up
    //wait for data ready
    if (digitalRead(data) == LOW);
    byte highBYTE = shiftIn(data, sclk, MSBFIRST);//shift all three bytes in
    byte midBYTE  = shiftIn(data, sclk, MSBFIRST);
    byte lowBYTE  = shiftIn(data, sclk, MSBFIRST);
    digitalWrite(sclk, HIGH); // polling pulse
    Serial.println(highBYTE);//print all three bytes
    Serial.println(midBYTE);
    Serial.println(lowBYTE);
I get a constant printed value of 255.
Here’s the datasheet http://www.ti.com/lit/ds/symlink/ads1231.pdf
Also this thread was for a similar chip, but his code didn’t work for me either. http://forum.arduino.cc/index.php/topic,128823.0.html
Thanks in advance for your help.
  if (digitalRead(data) == LOW);Semicolon ?
Thanks for your comment.
I delete semicolon and this error was occurred:
C:\Users\PC\Documents\Arduino\sketch_nov19b\sketch_nov19b.ino: In function ‘void loop()’:
sketch_nov19b:34: error: ‘highBYTE’ was not declared in this scope
exit status 1
I was edited with this:
// Serial.println(highBYTE);//print all three bytes
But the result is still the same:
Serial print:
255
255
255
Which code lines will be executed if digitalRead(data) returns LOW ?
Will highBYTE be declared if digitalRead(data) returns HIGH ?
Which code lines will be executed whatever digitalRead(data) returns ?
Note that I have Auto Formatted the code to emphasise the problems
I'm going to use this chip for Measure the output voltage of a photo diode (100 m V to 800 m V)!!!
Is it possible?
Can you answer the questions in post #3 ?
UKHeliBob:
thanks for this but i’m beginner to programming and only want to display result in serial monitor
thanks for this but i'm beginner to programming and only want to display result in serial monitor
and the answers to the questions ?
Suggestion 1. Always put { and } round the block of code to be executed as a result of testing a value even if there is only one line of code.
Suggestion 2. Put each { and } on its own line with nothing else
Suggestion 3. After doing 1 and 2 above Auto Format your code in the IDE
Is it possible?
