I used the arduino to create a program and then I installed the atmega328 in a curcuit that I built. I soldered the atmega directly to the board so I have to use a parallel programmer to put in a new updated program.
I built this parallel programmer to use with it and I have an in circuit programming port. I saved the PDE file and then I accessed the .HEX file in the applet, but I am not sure what the best way to go about getting the hex file onto the atmega is. If someone has some info on this please let me know. I downloaded winAVR, but I'm not sure if that is what I need.
When working with an external programmer - you create a new entry in "boards.txt" which redirect upload to your programmer (rather than the Arduino bootloader). Once you selet this board (properly configured) you can upload directly through the Arduino IDE.
I tried instead to change the "preferences.txt" file. I know I need to change the "upload.using=" line to one of the programmers in my "programmers.txt" file.
Here is my programmers.txt file. Can someone please explain to me the proper syntax to get this to work with the parallel programmer found HERE?.
