hi, I'm trying to use this board to save space in my wireless project.
I'm following this tutorial, using an arduino UNO as ISP programmer but I don't know how to set arduino IDE to burn the bootloader and the sketch....
any help?
tnk
Mauro
any help?
tnk
Mauro
Follow the instructions here:
tnks to pointing me!!
my settings:
Arduino IDE 1.8.5
board: atmega48
bootloader:NO
clock: 16 mhz external
compilier LTO: disabled
variant: 48/48A
BOD: disabled
port: arduino uno
programmer: arduino as ISP
when, for fuse reason, I try to burn the bootloader this is the error:
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/cepics/Library/Arduino15/packages/MiniCore/hardware/avr/2.0.1/avrdude.conf"
User configuration file is "/Users/cepics/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodemFD121
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega48
Chip Erase delay : 45000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 256 4 0 3600 3600 0xff 0xff
flash 65 6 64 0 yes 4096 64 64 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
Error while burning bootloader.
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
and this is the error when trying to upload blink sketch:
this check.
An error occurred while uploading the sketch
tips?
tnks a lot
my wiring:
arduino uno >>>>>>> ATmega48 + NRFL2401
(programmer) (to program)
D11 >>>>>>>>>>>>>>> MOSI
D12 >>>>>>>>>>>>>>>> MISO
D13 >>>>>>>>>>>>>>> SCK
D10 >>>>>>>>>>>>>>>> RESET
GRD >>>>>>>>>>>>>>>> GRD
5V >>>>>>>>>>>>>>>> 5V
I'm using the arduino as isp sketch on the example folder whitout modification...
but when I try to upload a sketch on ATmega48 + NRFL2401 board, this is the IDE output:
Arduino: 1.8.5 (Mac OS X), Board: "ATmega48, No, 48P / 48PA, Disabled, Disabled (default), 16 MHz external"
Sketch uses 382 bytes (9%) of program storage space. Maximum is 4096 bytes.
Global variables use 9 bytes (1%) of dynamic memory, leaving 503 bytes for local variables. Maximum is 512 bytes.
this check.
option enabled in File -> Preferences.
tips?
I think on this chip there is already a program for the communication NRF<->Arduino through I2C
Are you sure you can program this chip ?
nid69ita:
Yes, the processor was delivered pre-programmed with an SPI to I2C converter (source unknown).
While it should theoretically possible to reflash the device, the first thing the OP needs to understand is that the board does not contain a crystal so the selection of 16 MHz external will not work. The internal 8MHz option is the correct (and only) choice for that board. But, that’s not what is preventing the programming.
The invalid device signature is most likely a wiring error. The text based description isn’t at all adequate to provide the detail needed. Could you please post a photo clearly showing the connections between the two boards?
Edit: disregard the picture request. You do have the NRF24 module removed when programming, correct?
Found the schematic online:
I tried programing a duplicate board I had lying about and was unsuccessful, same result as you. I also tried removing C6 but this failed as well. Not sure what to do next, out of time for now.
If you did a Burn Bootloader with Tools > Clock set to an external clock and there is no external clock connected to the ATmega48 then you bricked the ATmega48. You will need to connect an external clock source to the ATmega48 long enough to do another Burn Bootloader with an internal clock selected.
